Thanks for notice, I will try to fix.Rockrider99 wrote:
With version 1.15.1 (32 bits), the Backup fonction generate an empty directory if I select the 4th option Thumbnails Cache.
Looks like impossible to open to .DAT/IDX files (seen messages in the log once). No more messages now but still empty directory as a result.
All is fine if I select only among the first 3 options (database, settings, devices)
Backup empty if Thumbnails Cache selected
Re: Backup empty if Thumbnails Cache selected
