Hello there,
Right now my album cover is only visible on the MP3 file. i would like to have the Cover on the album folder. Is there any way to do that?
Album Cover on Album not file
Re: Album Cover on Album not file
Yes, WMS supports the Cover on the album folder by default (devices very rarely)Reggie wrote: Right now my album cover is only visible on the MP3 file. i would like to have the Cover on the album folder. Is there any way to do that?
I tried adding a cover manually to the albumfolder, it worked. how can i set it to take the picture out of the folder itself just as the files do?
I think, you're talking about the other foldersWMS supports the Cover on the album folder by default
Im talking about the folders on the pic attached. But i took another look at it and it shows some pictures on the album folders.... it shows the same that are showing on my mobile as well but there is no diffrence of them to the other whose pictures are not showing.....
Kinda weird and i cant figure out whats the matter....
any ideas?
PS: in each folder is a picture folder.jpg and it shows the pic on every song, even on wms.
PPS: I sync my mp3 Database with my mobile.
any ideas?
- Unbenannt.PNG (8.4 KiB) Viewed 10832 times
any ideas?
Weird, all the files have a pic on it in almost every Folder.....
