Podcasts Gallery
palsoft
Contact:
Re: Podcasts Gallery
Post by palsoft »
could someone please help me with script which will be including this XML into Podcasts?
http://www.huste.sk/services/CurrentLive.xml
When the sport event goes live, it has this structure of live stream URL in the <event> tag
<files>
<file url="rtmp://n12.joj.sk/dat/huste/2012/01/15/sport-10662-hokej-15-01-12-banska-bystrica-zvolen-272p.mp4" label="272p" id="4" quality="lo" path="dat/huste/2012/01/15/sport-10662-hokej-15-01-12-banska-bystrica-zvolen-272p.mp4" type="rtmp-archiv"/>
<file url="rtmp://n12.joj.sk/dat/huste/2012/01/15/sport-10662-hokej-15-01-12-banska-bystrica-zvolen-360p.mp4" label="360p" id="1" quality="hi" path="dat/huste/2012/01/15/sport-10662-hokej-15-01-12-banska-bystrica-zvolen-360p.mp4" type="rtmp-archiv"/>
<file url="rtmp://n11.joj.sk/dat/huste/2012/01/15/sport-10662-hokej-15-01-12-banska-bystrica-zvolen-540p.mp4" label="540p" id="8" quality="540p" path="dat/huste/2012/01/15/sport-10662-hokej-15-01-12-banska-bystrica-zvolen-540p.mp4" type="rtmp-archiv"/>
</files>
P.S.: is there some possibility to transcode the game score directly into the video?
Thank you very much!
ashley
Post by ashley »
Im trying to get 4OD to work however when I update podcast nothing loads.
Can any one tell me if their is a system problem?
Regards
Ashley
ashley
Post by ashley »
I live within the UK, however when I try to update podcast for 4OD it does not load any progams. (I have no problems with BBC iPlayer or ITV Player)
If any one can help?
Regards
Ashley
ashley
Post by ashley »
Is anyone else having any problems with 4OD podcast?
How have you overcome updating problem?
Regards
Ashley
palsoft wrote: could someone please help me with script which will be including this XML into Podcasts?
huste_tv.zip
(1.55 KiB) Downloaded 2665 times
I do not have an example for live-streams, most likely will not work.
palsoft
Contact:
Post by palsoft »
Eugene, many thanks! Works like charm 8-)
timmcm
Post by timmcm »
Hi
Is there a podcast for http://au.tv.yahoo.com/7-mate/ and http://catchup.ninemsn.com.au/??
I am using the existing yahoo7 and ninemsn podcasts posted earlier in this thread , but I cant seem to access the TV shows on the above sites listed
Tim
jgeving88
Post by jgeving88 »
any way this will work for Amazon prime instant videos?
ashley
Post by ashley »
Hi
Has anyone been able to get 4OD working?
It hasnt worked for me for the last few months.
Does the srcipt need updating or is it to do with my setting?
Regards
Ashley
Thanatosgratus
Post by Thanatosgratus »
Would it be possible to create a podcast for http://www.tv3.ie/3player ?
