Settings - Devices - choose a device - Settings - "Files, Subtitles" - Border - Width - what a value ?
Subtitles go out of the screen
Re: Subtitles go out of the screen
From 0 to 100, it doesn't change anything on screen.
There must be something in settings!?!
Do you need *.ini setting file like
Try 1% or 0.5 (default value)
Hi!
That's it!!! That's the Width value
0,5 is better than 1 (1 seems too narrow)
Thank you very much, there's no more for me to be happy
Greetings
I set it on 0,4:
Greetings
I set it on 0,4:
- OK.jpg (118.31 KiB) Viewed 21372 times
I think, you need to change the border color to a darker, but it is a matter of taste.
Fix for the border width = 0%, will be in the next version. Thanks for message.
I put back the color border to black.
Merci et bon weekend
