Using PS3 with WMS. The problem is that the video quality of pre-transcoded file is poor when compared to the original file. What parameters can I change so that the pre-transcoded file quality is same as the original file. Currently, I'm using default settings of PS3.
I dont care about the size of pre-transcoded file because I've ultra fast computer, gigabit wired network (to all components) and tons and tons of storage. All I want is MAXIMUM video and audio quality. Have a 5.1 surround sound setup.
I appreciate your help
How to increase video quality of transcoded file?
Re: How to increase video quality of transcoded file?
Settings - Devices - PLAYSTATION 3 - Settings - Type - click "Restore from the distribution kit"
Are you try to say that the default settings of PS3 will transcode to best possible Video/Audio quality? If yes, I just want to let you know that I did not change any settings after installation. So, I'm on default settings only.
Can I not increase bitrate and FPS to a very high number so that I will always get the best possible quality?
Settings - Devices - PLAYSTATION 3 - Settings - Transcoder - "Codecs, frame" - "Video bitrate"
