Hello guys,
first sorry for my bad english.
I have installed the latest WMS on my PC (Athlon 3000+, RAM 1.5GB, NVidia 6600GT). Everything with playing movies is OK, except that sometimes movies hacked.
But when i play MKV movie in 1920x1080 - there are no subs?!?! It happens in MKV movies 1280x720 sometimes, but not at all.
I have written a lot of ways in this forum how to fix that, but nothing helped me. I have made a directory for subtitels and i have browseed it, but.. nothing!
Please help me how to fix that! I have 8 days till evulation period, and if i cannot fix that i will not buy it!
But this media server is the best for me of all that i have seen.
Thank you guys in advance!
Subtitles problem with SONY EX500
Re: Subtitles problem with SONY EX500
Does nobody knows???
Even when i integrate the subtitles in the movie i cannot see them again?!?!?
I cannot understand really why??
When I choose not SONY TV, but Unknown device - there ARE Subtitles, but the movie hacked.
Any suggestions??
Any suggestions??
rickymartin
I´m missing subtitles too f. e. for movies with Spartacus.
rickymartin
Becko where are you from? I speak Czech and English. I think problem with subtitles should be solved out by using "TS-muxer" profile for mkv. I still see no logic how to set up TS muxer profile in WMS or on my TV? I suppose that if in WMS than every movie will be played using TS muxer but if I set up it in TV it is only for one video file or will it be remembered for next time? This is mystery for me. I need to do more testing I´m still on the beginning after using it for several months licensed
I'm from Bulgaria rickymartin. What do you mean to set up in the TV! Where I can tune in my TV?rickymartin wrote:Becko where are you from? I speak Czech and English. I think problem with subtitles should be solved out by using "TS-muxer" profile for mkv. I still see no logic how to set up TS muxer profile in WMS or on my TV? I suppose that if in WMS than every movie will be played using TS muxer but if I set up it in TV it is only for one video file or will it be remembered for next time? This is mystery for me. I need to do more testing I´m still on the beginning after using it for several months licensed
I have tried to use TSMUXER profile but... nothing chanaged!
rickymartin
I mean set up TSMUXER on your remote controller on your tv, in transcoding profile. Where exactly you seted it up?
Becko wrote:I'm from Bulgaria rickymartin. What do you mean to set up in the TV! Where I can tune in my TV?rickymartin wrote:Becko where are you from? I speak Czech and English. I think problem with subtitles should be solved out by using "TS-muxer" profile for mkv. I still see no logic how to set up TS muxer profile in WMS or on my TV? I suppose that if in WMS than every movie will be played using TS muxer but if I set up it in TV it is only for one video file or will it be remembered for next time? This is mystery for me. I need to do more testing I´m still on the beginning after using it for several months licensed
rickymartin wrote:I mean set up TSMUXER on your remote controller on your tv, in transcoding profile. Where exactly you seted it up?
- WMS.jpg (179.76 KiB) Viewed 14189 times
rickymartin
Eugene, where is possible in WMS to move subtitles up? Thanks.
What do you mean?rickymartin wrote:Eugene, where is possible in WMS to move subtitles up? Thanks.
rickymartin
I would like to move subtitles up from bottom of the screen, because currently is part of it not visible.
Eugene wrote:What do you mean?rickymartin wrote:Eugene, where is possible in WMS to move subtitles up? Thanks.
