Script Guide
Script Guide
Hi - is there a scripting guide, I can see three places to place scripts for podcasts and am unsure which purpose each serves.
Also I notice some functions that look specific to WMS - are these documented?
Re: Script Guide
Additional classes and functions on the right.
Examples: WMS - Settings - Transcoder - Profiles - Transcoding profiles list
WMS - Settings - Processing
Podcast Gallery: http://www.wildmediaserver.com/forum/vi ... f=20&t=259
In the scripts used by well-known languages Pascal, C++, Java, Basic (FastScript - http://www.fast-report.com).hepple wrote:is there a scripting guide, I can see three places to place scripts for podcasts and am unsure which purpose each serves.
Re: Script Guide
Thanks, I was wondering if their was a description of what the functions do, e.g. WmsJsonDecode etcEugene wrote:Hi,In the scripts used by well-known languages Pascal, C++, Java, Basic (FastScript - http://www.fast-report.com).hepple wrote:is there a scripting guide, I can see three places to place scripts for podcasts and am unsure which purpose each serves.
Re: Script Guide
Basically, the names speak for themselves. http://www.json.org/hepple wrote:Thanks, I was wondering if their was a description of what the functions do, e.g. WmsJsonDecode etcEugene wrote:Hi,In the scripts used by well-known languages Pascal, C++, Java, Basic (FastScript - http://www.fast-report.com).hepple wrote:is there a scripting guide, I can see three places to place scripts for podcasts and am unsure which purpose each serves.
samsungfan
Re: Script Guide
Can you give a basic tutorial on how to create MediaResourceLink given a webpage with the flash player embedded?
What are the exact steps you follow to create the script to resource given the end page where the flash video is playing?
Take an example of http://cricfire3.blogspot.com/2010/10/l ... ver-1.html. Given that the ICC world cup 2011 is going on, it will be useful to know.
Re: Script Guide
Main - the use of proxy-server.samsungfan wrote:Can you give a basic tutorial on how to create MediaResourceLink given a webpage with the flash player embedded?
samsungfan
Re: Script Guide
Can you clarify further on "proxy server"?
Re: Script Guide
http://en.wikipedia.org/wiki/Proxy_server#Web_proxysamsungfan wrote:Can you clarify further on "proxy server"?
samsungfan
Re: Script Guide
What do you recommend for proxy server?
Re: Script Guide
Charlessamsungfan wrote:What do you recommend for proxy server?
