I am trying to create a thumbnail for a .mpg file (actually it does not work for any type of video file) using the rightclick "Create thumbnail" menu option. However, I get the error "Create thumbnail failed." and no thumbnail is created. I looked for a log file, however I can't seem to find one that contains any useful information.
Specifics:
WMS Version: 1.07.3
O/S Version: Windows Server 2008 R2 x64
Regards,
themoosman
Edit:
This use to work in the 1.05.x version of the program.
spionwanze
Re: Create thumbnail failed
same problem:
WMS 1.07 on Windows Home Server (based on Windows 2003 Server)
Create Thumbnail for "\\Server\Videos\Filme Trailer\A Fork in the Road.mp4" -->ok
Create Thumbnail for "\\Server\Videos\Filme Trailer\A Serious Man.mp4" --> failed
...like for most movies.
Is there a problem with Windows Server...maybe missing Codecs or something?
K-Lite Codec Pack and VLC are installed.
On my Windows 7 PC i never had problems with thumbnails for the same Movies!
Which exe is used for Thumbnails? wmsmpeg.exe ???
same problem:
Yes, to create thumbnails using wmsmpeg.exe (ffmpeg-1.dll).
I have a few mp4 files, no problems.
themoosman
If I dump to a command prompt and use the following command:
It generates a jpg just fine. Is it possible that the UI command has an issue?
depends on the parameter ss (Settings - Device - Movie start time)themoosman wrote:If I dump to a command prompt and use the following command:
It generates a jpg just fine. Is it possible that the UI command has an issue?Code: Select all
themoosman
I change the setting from the default of 480 to 5 (restarted server) and tried it again and got the same error.
- Capture.PNG (22.07 KiB) Viewed 12690 times
themoosman
Yep.Eugene wrote:Good thumbnail ?Code: Select all
If there is a small sample file, I can check what the problem is
themoosman
PM sent.Eugene wrote:If there is a small sample file, I can check what the problem is
