Hi all,
i'm evaluating wms and it's incredible.
i would like to know if there is a way to disable wireless connection on my laptop
through a script in the server session.
i'm running windows 7 and i have a script in powershell to do so.
is it possible to run a powershell or a shell script from wms?
many thanks
Regards
						disabling wifi
Re: disabling wifi
						Server - Settings - "The list of authorized network connections" - SearchBooleano wrote: i'm evaluating wms and it's incredible.
Re: disabling wifi
hi
thanks a lot for your reply.
I didn't explain correctly my question:
i would like to add some kind of automation script, so i can disable my wireless card through a script
on the client.
at the moment i can restart the server, the computer etc. from the client connected to wms,
but i would also like to execute whatever batch file i want on the pc hosting wms...so for example disable the
wifi card or other scripts .bat or powershell.
is there a way to do so?
many thanks
on the client.
many thanks
Re: disabling wifi
						For media resource can be assigned a transcoding profile. In a transcoding profile you can use ole-objects. As the transcoder you can use any program with the parameters of the call.Booleano wrote: thanks a lot for your reply.
on the client.
many thanks
