I have a panasoniv VT20 3D. When i play MKV/DVD/ISO/AVI al work fine and it does the job good. Now here is the problem.
When I enable SUbtitles through Tanscoding, the subtitles are show but my video/ audio stutters every 4 seconds. When i disable the subtitles all is playing smooth again.
Anybody know why that is?
Cheers
Hemant
						PANASONIC P50VT20E Subtitle problem
Re: PANASONIC P50VT20E Subtitle problem
						Resources of your computer is not enough to transcode on the fly.hemant wrote: I have a panasoniv VT20 3D. When i play MKV/DVD/ISO/AVI al work fine and it does the job good. Now here is the problem.
Thank for yourreply.
Funny you say that. My server quad-core 4GB memory. I have checked the machine whil that happens.
CPU is idle disk is also idle.
						Tried to use the pause on remote control ?hemant wrote: Funny you say that. My server quad-core 4GB memory. I have checked the machine whil that happens.
Yes did but no effect.
Another think is that de sub look strange on the screen.
Noone has similar problems?
