Released a version "Wild Media Server (UPnP) v1.05.4"
Update file from version 1.04.7
How to update the program:
1. Download the update file.
Wild Media Server (UPnP, DLNA, HTTP) v.1.05
1. Added device configuration:
- "DLNA Device (version 1.5, 16:9, 720x406)";
- "DLNA Device (version 1.0, 16:9, 720x406)".
2. The distribution includes a Italian translation file (thanks to the user aka Libero),
choose Help-Language.
3. The distribution includes a Romanian translation files (thanks to the user aka Gugu),
4. In the registration of file types added a possibility enumeration MIME-types and
DLNA-information separated by a comma, the examples in the device configuration
"DLNA Device (version 1.5, 16:9, 720x406)" and "DLNA Device (version 1.0, 16:9, 720x406)".
5. Added possibility to set up the grouping of files into folders "Collections", "Playlists", "Albums".
Actions (for example, "Playlists"):
- add a folder in the "Playlists";
- drag & drop the column header "Artist" to the added folder;
- open the folder "Grouping";
- drag & drop the column header "Album" to the line "ReplaceStr (mpAuthor, ',', #13#10)"
- grouping: "Artist" - "Album"
For each folder, the results of grouping can set their own rules follow grouping, it can be convenient, for example, genre of music:
- drag & drop the column header "Genre" to the added folder;
- drag & drop the column header "Artist" to the line "ReplaceStr (mpGenre, ',', #13 #10)"
- drag & drop the column header "Composer" to the line of the genre "Classical"
- grouping: "Genre" - "Artist", for the genre "Classical" grouping by the composer.
6. Added a separate language setting by default for subtitles and audio tracks (Settings-Transcoder-Subtitles).
7. For files ape, flac, wv now not set a transcoding profile when Scan,
transcoding profile is set to File types, used if the files are not included
in the list of supported.
8. Server port default changed from 0-auto on 45357.
9. Added scripts of media resources processing "Download podcast",
"Pre-transcoding (media-resource)", "YAMMM mymovies.xml import".
Update on version 1.05.1
- added auto-update language files in Languages directory;
- updated language file setup (added Romanian, Bulgarian);
- podcast update fix.
Update on version 1.05.2
- to section Photo added Podcasts folder;
- in Web-navigation added a playlist for all items in a folder;
- updated language file setup (added Polish);
- updated subtitles module.
Update on version 1.05.3
- updated transcoder FFMPEG (SVN-r25118);
- added Polish language file (thanks to the user aka Mperchel);
- added registration wbem-files;
- updated sctipt for IMDB.
Update on version 1.05.4
- fixes FFMPEG;
- added Dutch language file;
- updated Polish language file.
Re: Released a version "Wild Media Server (UPnP) v1.05rc2"
Update on version 1.05rc2
- added a Romanian translation files (thanks to the user aka Gugu), choose Help-Language;
- updated the device configurations "DLNA Device (version 1.5, 16:9, 720x406)" and "DLNA Device (version 1.0, 16:9, 720x406)";
- changes to support foobar2000 UPnP Browser.
Update on version 1.05rc3
- fixed a possible error (AV) after updating podcasts in the main form of the program;
- server port default changed from 0-auto on 45357.
Re: Released a version "Wild Media Server (UPnP) v1.05rc3"
Update on version 1.05rc4
- updated Romanian translation file;
- added scripts of media resources processing "Download podcast", "Pre-transcoding (media-resource)", "YAMMM mymovies.xml import" (viewtopic.php?f=19&t=109);
- fixes for editing grouping of files.
gugu
Re: Released a version "Wild Media Server (UPnP) v1.05rc4"
Post by gugu »
I can't update.
I get errors all over.
Cheers
gugu
Post by gugu »
here is the window
Cheers
gugu wrote:I can't update.
Perhaps you changed the files, you can install with the distribution and update. Do not lose your changes.
Update on version 1.05rc5
- different fixes
Re: Released a version "Wild Media Server (UPnP) v1.05rc5"
Update on version 1.05rc7
- updated setup.exe (support external localization);
- added setup.sln - localization file (English, Russian)
- updated wmsmpeg.exe (removed VLC support);
- fixed problem with photo (WDTV Live);
- improve server with transcoded content, if list of allowed clients is empty.
Re: Released a version "Wild Media Server (UPnP) v1.05"
- added check Windows Firewall rules.
