Hi together,
funny problem here.
I installed WMS and it looks like it is running alright.
My Blueray Combo doestn detect the WMS Server running, but as soon as i go under "Settings" - "Device" - and start the search of my clients
the Blueray Combo finds the WMS Server and can easily be accessed. As soon as the search is finished the connection is lost and even if I restart
the WMS Server there is no chance to get it running on the Blueray Combo.
Any ideas why this is happening ?
Kind regards
Bengt
						HT-C5550 WMS not found
Re: HT-C5550 WMS not found
If you use a firewall program, check its rules for the module wms.exe (if the server runs as a service Windows, the module wmssvc.exe), possible transfer program firewall in training mode, restart the program "Wild Media Server (UPnP, DLNA, HTTP)" .
						http://www.wildmediaserver.com/forum/vi ... hp?f=3&t=6Bengt79 wrote: I installed WMS and it looks like it is running alright.
Firewall was the problem, thx !!! Had The WMS itself in my Firewall but not the service.... as soon as i added it everything is running fine !!!  THX
