Has anyone tried PowerDVD's UPnP client feature with WMS?
I downloaded it and can navigate the WMS folder structure, but no files are displayed in the folder so I can't stream anything.
I was curious if anyone has tried this and had any luck.
Are there any Windows UPnP Clients that work with WMS???
CyberLink PowerDVD version 10 Ultra 3D
Re: CyberLink PowerDVD version 10 Ultra 3D
Device type: Philips TV 2008 (DLNA, 16:9, 1280x720)djo_34 wrote:Has anyone tried PowerDVD's UPnP client feature with WMS?
Client features are very limited at first glance.
WMP, Nero, XBMC. Best of all I think VLC in a web-mode.djo_34 wrote: Are there any Windows UPnP Clients that work with WMS???
Any Windows UPnP clients that support MKV?
WMP and Nero don't. VLC uses PowerDVD plugin. If PowerDVD doesn't work, my guess is that VLC doesn't either.
But thanks for the response.
I installed Haali Media Splitter (http://haali.su/mkv/). Now WMP support mkv (Windows 7), PowerDVD doesn't work.djo_34 wrote:Any Windows UPnP clients that support MKV?
WMP and Nero don't.
XBMC also have no problems.
VLC contains everything you need for playback most common formats, problems c mkv not.djo_34 wrote: VLC uses PowerDVD plugin. If PowerDVD doesn't work, my guess is that VLC doesn't either.
