i have a problem with some mp4 files. Most of my mp4 files are working without any problems.
But i bought a new camera (Sony Cybershot DSC-WX1) and all these mp4 movies are not added to the index??
THX!!
Ben
Here some media infos:
Complete name                    : G:\movie\test\test.mp4
Format                           : MPEG-4
Format profile                   : Sony PSP
Codec ID                         : MSNV
File size                        : 35,9 MiB
Duration                         : 34s 34ms
Overall bit rate                 : 8 849 Kbps
Encoded date                     : UTC 2010-05-31 20:00:24
Tagged date                      : UTC 2010-05-31 20:00:58
Video
Format                           : MPEG-4 Visual
Format profile                   : Advanced Coding Efficiency@L4
Format settings, BVOP            : YES
Format settings, QPel            : no
Format settings, GMC             :  no warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : 20
Duration                         : 34s 34ms
Bit rate mode                    : variabel
Bit rate                         : 8 782 Kbps
Nominal bit rate                 : 9 000 Kbps
Maximum bit rate                 : 14,0 Mbps
Width                            : 1 280 Pixel
Height                           : 720 Pixel
Display aspect ratio             : 16:9
Frame rate mode                  : konstant
Frame rate                       : 29,970 FPS
Resolution                       : 8 bits
Scan type                        : progressiv
Bits/(Pixel*Frame)               : 0.318
Stream size                      : 35,6 MiB (99%)
Audio
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format version                   : Version 4
Format profile                   : LC
Format settings, SBR             : YES
Format settings, PS              : YES
Codec ID                         : 40
Duration                         : 34s 5ms
Bit rate mode                    : konstant
Bit rate                         : 64,0 Kbps
Channel(s)                       : 2 Kanäle
Channel positions                : Front: L R
Sampling rate                    : 48,0 KHz
Stream size                      : 266 KiB (1%)
Re: problem with some mp4 files
						Update program on 1.01-1.02benschy wrote: i have a problem with some mp4 files. Most of my mp4 files are working without any problems.
