Hi Eugene
one more question....
Samsung B series (LE40B750) support MKV native, but no DTS audio track......
optimal config is demux - transcode DTS to AC3 and mux back -play....
I check on the fly profiles:"Movies (primary)" a "Movies - TsMuxer"
"Movies (primary)" work great, but transcode audio and video - more power on procesor needed (not work on old PC)
"Movies - TsMuxer" is more sophistical....but do not work corectly for samsung TV..... demux - transcode DTS to AC3 and mux work fine, but destination m2ts file Samsung TV not play correctly video is jerky, frame rate up and down.... not good
I made test file with test transcodig function and copy him to USB HDD and play on TV directly - output is the same (jerky, atd.......)
rommi
Samsung TV B series streaming mkv DTS with audio transcoding
- DTS-AC3 -TSmux.JPG (127.47 KiB) Viewed 22127 times
Re: Samsung TV B series streaming mkv DTS
Any problems when transcoding I do not see. You can try to use the profile "Movies - DirectShow - TsMuxer", to decode the audio requires FFDShow.
P.S. LE40B750 - 200Hz LCD TV ? It may be necessary to align the frame rate to 24 or 25.
Original file without sound is played normally?rommi wrote: one more question....
michiel1981
Re: Samsung TV B series streaming mkv DTS with audio transcoding
what about the max_analyze_duration reached.... i read somewhere you can fix this by doing -vsync 1
HiEugene wrote:Hi,
..Yes origina MKV file (wo sound of course..) play normaly. frame rate 23,976 is not problem.......
I installed ffdshow - latest release from http://www.free-codecs.com/download/FFDShow.htm version wo MMX and SSE
1. I aply "Movies - DirectShow - TsMuxer" profile for the same movie and result is..... WMS crash...
2. I aply "Movies - DirectShow - TsMuxer" profile to another MKV file with AC3 sound track - muxing work, but video is jerky (the same as "Movies - TsMuxer")and sound is out of sync cca 1,5-2 sec after video....
- wild crash.JPG (123.11 KiB) Viewed 22092 times
-vsync 1 ???? as parameter for command line on transcoding script...???? or...???michiel1981 wrote:what about the max_analyze_duration reached.... i read somewhere you can fix this by doing -vsync 1
Fix will be in version 0.72.1rommi wrote: I installed ffdshow - latest release from http://www.free-codecs.com/download/FFDShow.htm version wo MMX and SSE
1. I aply "Movies - DirectShow - TsMuxer" profile for the same movie and result is..... WMS crash...(see image)
If the file is created in a test transcoding, copy to directories of media resources and play without transcoding, the problem exist ?rommi wrote: 2. I aply "Movies - DirectShow - TsMuxer" profile to another MKV file with AC3 sound track - muxing work, but video is jerky (the same as "Movies - TsMuxer")and sound is out of sync cca 1,5-2 sec after video....
Yes, problem is the same....transcode MKV to M2TS and stream as native file.....Eugene wrote:Hi,If the file is created in a test transcoding, copy to directories of media resources and play without transcoding, the problem exist ?rommi wrote: 2. I aply "Movies - DirectShow - TsMuxer" profile to another MKV file with AC3 sound track - muxing work, but video is jerky (the same as "Movies - TsMuxer")and sound is out of sync cca 1,5-2 sec after video....
I think the TV problems playing H.264 in m2ts-format. Try to find the original m2ts-files (BlueRay) with the video track H.264, frame rate 23.976, and play them. May need to change the DLNA-profile m2ts-files.rommi wrote:Yes, problem is the same....transcode MKV to M2TS and stream as native file.....Eugene wrote:Hi,If the file is created in a test transcoding, copy to directories of media resources and play without transcoding, the problem exist ?rommi wrote: 2. I aply "Movies - DirectShow - TsMuxer" profile to another MKV file with AC3 sound track - muxing work, but video is jerky (the same as "Movies - TsMuxer")and sound is out of sync cca 1,5-2 sec after video....
When trying Movies - DirectShow - TsMuxer I get an error on line:
if not CheckResult(WmsDirectShowConnectPin('Audio Decoder', 'DumpAudio', 'Out', '',
MEDIATYPE_Audio, KSDATAFORMAT_SUBTYPE_PCM)) then
Exit;
Win7 64
Exit;
Win7 64
Check settings FFDShow Audio Decoder (Section Output)mkukik wrote:When trying Movies - DirectShow - TsMuxer I get an error on line:
Exit;
Win7 64
