First off this is a great product!
Is there any way to get the cover art from IMDB to auto populate the videos rather than having to do it one by one? I have over 500 movies and this can take some time.
Cover Art
Re: Cover Art
I think that is possible through the processing of media resources, but the result may be uncertain (same title of the film, vague title of the film). No ready-made scripts.Dark_Wizard wrote: Is there any way to get the cover art from IMDB to auto populate the videos rather than having to do it one by one? I have over 500 movies and this can take some time.
Dark_Wizard
Re: Cover Art
There are ready made IMDB scrapers out there...any possibility to add one to you product in a future release?
Re: Cover Art
If there is a ready-made scripts, they can post on the forum, with the permission of the author, they will be included in the distribution.Dark_Wizard wrote:There are ready made IMDB scrapers out there...any possibility to add one to you product in a future release?
Dark_Wizard
Re: Cover Art
I have another suggestion...can you have it where we have a cover art folder with the same naming as the video files and it pulls from that folder and displays?
Re: Cover Art
Unfortunately, it is impossible to specify the full path to the thumbnail, but you can connect the file if it is in the same directory as the movie file or the cache directory thumnails. In future version I provided the ability to specify the full path to the thumbnail.Dark_Wizard wrote:I have another suggestion...can you have it where we have a cover art folder with the same naming as the video files and it pulls from that folder and displays?
Script to connect thumbnail in the current version. Cache directory in Windows XP: C:\Documents and Settings\All Users\Application Data\Wild Media Server\Thumbnails.
Settings - Processing - Add
Name: Search thumbnails
Check "Button on the main form".
CSIDL_COMMON_APPDATA = $0023;
sThumbnailCacheDirectory: string = '';
sFileName, sThumbnailFileName: string;
sFileName := aItem.Properties[mpiFilePath];
sThumbnailFileName := ExtractFileName(ChangeFileExt(sFileName, '.jpg'));
if FileExists(ExtractFilePath(sFileName) + sThumbnailFileName) then
aItem.Properties[mpiThumbnail] := sThumbnailFileName
else if FileExists(sThumbnailCacheDirectory + sThumbnailFileName) then
aItem.Properties[mpiThumbnail] := '?' + sThumbnailFileName
AllMoviesFolder: TWmsScriptMediaItem;
sThumbnailCacheDirectory := IncludeTrailingBackslash(SpecialFolderPath(CSIDL_COMMON_APPDATA)) +
'Wild Media Server\Thumbnails\';
AllMoviesFolder := WmsFindMediaFolder(mfVideoAllMoviesItemID);
if (AllMoviesFolder <> nil) and (AllMoviesFolder.ChildCount > 0) then begin
WmsShowProgress('Search thumbnails...');
try
for i := 0 to AllMoviesFolder.ChildCount - 1 do begin
if WmsCancelPressed then
Break
else begin
ProcessItem(AllMoviesFolder.ChildItems[i]);
WmsSetProgress(Round(((i + 1) / AllMoviesFolder.ChildCount) * 100))
finally
WmsHideProgress
MessageDlg('Search thumbnails interrupted by the user.', mtError, mbOK, 0)
else begin
WmsDatabaseAutoSave;
MessageDlg('Search thumbnails is successful.', mtInformation, mbOK, 0)
end else
MessageDlg('No files to process.', mtError, mbOK, 0);
ProcessMediaResult := True
