Gametrailers.com
Re: Gametrailers.com
moqwai wrote:
i'm having a problem with the gametrailers-podcast. The sections "feature" and "gameplay" are not working properly. Test transcoding gives me "error -2 occurred" and the url is not showing (first line usuallly: "c:/programs/...../wmsmpeg.exe" -i "http://trailers...", but in "feature" and "gameplay": :"c:/programs/...../wmsmpeg.exe" -i "", so, no url is existing).
The links in the main window are correct and working properly, even at editing the podcast in the link-section.
Tried different platforms (PS3, XBOX360, PS2, Wii). Only PC-section works.
Some ideas?
Try this
Gametrailers.zip
(2.83 KiB) Downloaded 1513 times
moqwai
Post by moqwai »
working perfectly. Your server is worth every cent. Have some issues with transcoding hd-files, but thats not the point in this thread ;)
banafaen
Post by banafaen »
Any chance of making script for http://g4tv.com/ like the gametrailers.com script? Ps3, xbox360, previews, e3 etc
They have webshow RSS feeds (http://g4tv.com/podcasts/index.html) , that are easy to add to podcasts, but not all the other videos that are posted.
And perhaps: http://video.ign.com/ :)
thx for the gametrailers script btw! works exellent :)
-bana
banafaen wrote:Any chance of making script for http://g4tv.com/ like the gametrailers.com script? Ps3, xbox360, previews, e3 etc
G4TV (XBOX 360, PS3, Wii, PC, DS, PSP)
g4tv.zip
(3.51 KiB) Downloaded 1550 times
moqwai
Post by moqwai »
Yes, but only 15 videos in each category are displayed. Any chance of showing more?
moqwai wrote:Yes, but only 15 videos in each category are displayed. Any chance of showing more?
Updated - http://www.wildmediaserver.com/forum/vi ... 3050#p3050
banafaen
Post by banafaen »
thx for g4tv script, but seems it times out when trying to update podcasts. Nothing in the log. just "The operation timed out". I got the last g4tv.wdf you made.
In addition, gametrailers now only shows one or two podcast per category. Used to be over a thousand video podcasts, now its only 22 :)
I have checked the firewall and port 1935 is open (rtmpdump.exe) and got ver 1.04.5 + win7
any idea what the problem could be?
cheers
-bana
banafaen wrote:thx for g4tv script, but seems it times out when trying to update podcasts. Nothing in the log. just "The operation timed out". I got the last g4tv.wdf you made.
What folder ?
banafaen wrote: In addition, gametrailers now only shows one or two podcast per category. Used to be over a thousand video podcasts, now its only 22 :)
Thanks for info, updated http://www.wildmediaserver.com/forum/vi ... 1697#p1697
banafaen wrote: I have checked the firewall and port 1935 is open (rtmpdump.exe) and got ver 1.04.5 + win7
It is not used rtmpdump.exe
banafaen
Post by banafaen »
All of the g4tv folders times out when i try to update. Nothing in the log either.
Gametrailers works perfect again :) thx
-bana
banafaen wrote:All of the g4tv folders times out when i try to update. Nothing in the log either.
G4TV - XBOX 360 - Videos - on right click "Edit name" - Link - click "View feed..." - page opens ?
