Can't access WMS from Sony Bravia KDL 46 EX 505 TV
wildone1965
Post by wildone1965 »
Hello Folks,
I just installed and setup WMS. My TV finds the Server but when I try to connect I get an error saying I cant connect to the server.
Like I said, I am very new to this program and i would be happy if i get this running before the 15 days are over so i can buy the correct licenses.
Thanks in advance.
Re: Can't access WMS from Sony Bravia KDL 46 EX 505 TV
wildone1965 wrote: I just installed and setup WMS. My TV finds the Server but when I try to connect I get an error saying I cant connect to the server.
Settings-Server-Port: try to set a permanent port from 1024 to 65535. Restart server.
wildone1965
Hello Eugene,
thank you for your quick response, but unfortunately your tip didnt help. I still cant access the server from the TV. In case you need some additional information or screenshots let me know.
Thx Wildone
wildone1965 wrote: thank you for your quick response, but unfortunately your tip didnt help. I still cant access the server from the TV. In case you need some additional information or screenshots let me know.
Log messages in main form of program ?
Try to open a presentation page in the Internet Explorer: http://server_ip_address:port
wildone1965
Hello Eugene
I cant get to the webinterface either. I hope i did it correctly. I used the computers fix IP adress where WMS is running from e.g "http://192.168.178.50:5000"
If i try to connect the browser tells me it could connect but i dont have the rights to do so. I am on a Vista System and i have an Admin user account, but i know that there are restrictions of some sort. Darn Vista :) "Error HTTP 403 forbidden"
wildone1965 wrote: I cant get to the webinterface either. I hope i did it correctly. I used the computers fix IP adress where WMS is running from e.g "http://192.168.178.50:5000"
If i try to connect the browser tells me it could connect but i dont have the rights to do so. I am on a Vista System and i have an Admin user account, but i know that there are restrictions of some sort. Darn Vista :))
Help-Contents-"Search server into a media device"
If you use a firewall program, check its rules for the module wms.exe (if the server runs as a service Windows, the module wmssvc.exe),
wildone1965
I checked and the "wms.exe" is not blocked by the firewall. As well as the "WMSSVC.exe". I run Kaspersky internet security 2010
wildone1965 wrote:I checked and the "wms.exe" is not blocked by the firewall. As well as the "WMSSVC.exe". I run Kaspersky internet security 2010
Settings - Additional - Autoload - turn off "Installation Windows Service" - Ok - Start server - check "Log messages".
wildone1965
Unfortunately still no access via webbrowser. Screenshot below
wildone1965 wrote:Unfortunately still no access via webbrowser. Screenshot below
Settings-Server-"A list of allowed network connections" - remove all or add webbrowser computer.
