Since you seem to be suggesting different settings, I am wondering if I am missing something, because I get stuttering every couple of seconds.
Thanks for doing a such a wonderful job and quick responses. I am not very technical with video formats. I am using the open video media from the below url, for testing, chose the smallest of the 2 files. I have not been able to figure out how to use the external USB hard drive, which is not recognised by the TV to test out the test transcoded video. Test transcoded video also has the same issue when played via WMS.
I am playing the following open media.
http://blender-mirror.kino3d.org/peach/ ... ny_movies/ which is download mirror for: http://www.bigbuckbunny.org/index.php/download/
big_buck_bunny_480p_h264.mov
big_buck_bunny_480p_stereo.avi
TV
Sony Bravia KDL-52Z5100
TV Specifications: http://www.sonystyle.com/webapp/wcs/sto ... ifications
Laptop
Dell Latitude E5400, Intel Core 2 Duo P8600 with VT 2.40GHz, 3M L2 Cache, 1066MHz FSB, 3 GB RAM, WIndows XP Professional
Network
Gigabit Wireless N Router. TV is connected to router via powerline adapter.
Network Utilization
Was just 1-3% on my Laptop
Created test file and played via WMS, still the same problem.
Sony Bravia KDL-52Z5100 Video Stuttering Gigabit Wired LAN
- New Wordpad Document (3).zip
- (179.15 KiB) Downloaded 822 times
- New Wordpad Document (2).zip
- (183.18 KiB) Downloaded 801 times
- Settings.zip
- (177.4 KiB) Downloaded 879 times
Re: Sony Bravia KDL-52Z5100 Video Stuttering Gigabit Wired LAN
Additional Screenshots
- New Doct.zip
- (228.97 KiB) Downloaded 784 times
If your TV is NTSC, select the configuration of the Sony TV NTSC (DLNA, 16:9, 720x406).UserWeb wrote:Since you seem to be suggesting different settings, I am wondering if I am missing something, because I get stuttering every couple of seconds.
TV
Laptop
Network
Network Utilization
I can check the playing of these resources only on Monday.
I am in NA, presume it is NTSC. You are the person!!!!!!!!!! That works. As some other poster was mentioning not able to go forward or back, can live with that for now, maybe that might work with a different video format.Eugene wrote:If your TV is NTSC, select the configuration of the Sony TV NTSC (DLNA, 16:9, 720x406).UserWeb wrote:Since you seem to be suggesting different settings, I am wondering if I am missing something, because I get stuttering every couple of seconds.
TV
Laptop
Network
Network Utilization
Basically, just a quick couple of questions,
presume except for changing profile, can I revert back all other settings? Should the transcoding setting still need to be changed to NTSC and all the other settings that you had previously suggested in the couple of other Bravia threads?
Once I am all set I will detail my settings(documentation) and willing to donate/purchase software if it is reasonable.
I am not sure that changes are meaningful. On documentation KDL-52Z5100 only supports MPEG-2, no mention of AVCHD.UserWeb wrote: I am in NA, presume it is NTSC. You are the person!!!!!!!!!! That works. As some other poster was mentioning not able to go forward or back, can live with that for now, maybe that might work with a different video format.
Main not use DLNA profile in which there is _PAL.
