Sony Bravia KDL-W5500 46 inch
michiel1981
Re: Sony Bravia KDL-W5500 46 inch
Post by michiel1981 »
Think thats a pretty good idea. Thanks ill try it right away.
You can try these settings viewtopic.php?p=198#p198
michiel1981
omg you are awesome :lol:
works perfectly now only tiny problem is i cant pauze the video anymore but i guess you cant have it all.
Im deff gonna buy your program ;)
michiel1981
Any idea if it still possible to get the subtitles working i notice they are still listed as mpeg and the video as acv
michiel1981 wrote:Any idea if it still possible to get the subtitles working i notice they are still listed as mpeg and the video as acv
What is the problem with subtitles?
michiel1981
They just wont show even if i select them. I have been reading a lot and seems streaming doesnt support the psg subs with m2ts files. Its werd since these are mkv files.
michiel1981 wrote:They just wont show even if i select them. I have been reading a lot and seems streaming doesnt support the psg subs with m2ts files. Its werd since these are mkv files.
Usually TVs do not support the display of subtitles, the program has the support of subtitles when transcoding.
Selecting subtitles in the track list is valid for the full transcoding (video+audio). Subtitle will not be with the transcoding profile "Movies-TsMuxer", subtitles will be the transcoding profile Movies (primary)
michiel1981
problem is the movie only runs when i have tsmuxer selected else i get playback not available but o well im rly happy with it the way it is even without subs.
McCoisty
Post by McCoisty »
I've followed this thread intently and made all the recommended changes here, I have a Bravia KDL-W5500 (although the 40inch version) also.
The movies will play if I do not set a "Transcoder Profile" but start to "buffer" after about 10 seconds or so.
If I select "Movies -TX Muxer" then "cannot playback" shows..
some screenshots.
McCoisty
Post by McCoisty »
continued...
any help/suggestions most appreciated!!
McCoisty :D
