I recently bought a KDL40EX503 Tv and from the info i have found i beleive it can playback DivX/ XviD/ AVI/ AVC video files over DLNA and USB.
So far i have everything working - able to stream all my video content to the TV via WMS. But so far its all seems to convert the content to mpeg2 - all video entries listed on the TV have meg2 next to them. These include video with mp4, divx, mkv and avi extensions. Most of my video files with mp4 extension are in mpeg-4 avc/h.264 format from my samsung camcorder.
I did get an m2ts clip to test and that showed up as AVC when listed on the tele - so assume that was not converted mpeg2. Also tested divx and mp4 files from usb stick and they played fine.
The device is set to Sony TV (DLNA, 16:9, 1920x1080) which is listed with m2t,m2ts,mpeg,mpg,ts,vob embedded file support.
SO my question is how do i get it to play the mp4, divx, mkv files without them being converted to mpeg2. Do i updated the media device profile somehow
Any help would be much appreciated
thanks Mike
Sony KDL40EX503 - playback DivX/ XviD/ AVI/ AVC video files
Re: Sony KDL40EX503 - playback DivX/ XviD/ AVI/ AVC video files
http://www.sony.co.uk/product/t32-ex-se ... nicalSpecsmikek wrote:I recently bought a KDL40EX503 Tv and from the info i have found i beleive it can playback DivX/ XviD/ AVI/ AVC video files over DLNA and USB.
thanks Mike
I think TV does not support playback of these files through DLNA. For mkv, mp4 files (H264), you can try to use the transcoding profile "Movies-TsMuxer", the choice of the right mouse button or Settings-File types-mkv-Edit-Transcoding profile-"Movies-TsMuxer" . In models 5500 Sony was very picky about the video frame size H264, information on new models none.DLNA
YES
DLNA Renderer
Photo (jpeg)/Music(LPCM/MP3)/Video(MPEG2/AVCHD)
DLNA Client
Eugene thanks for your quick response. That seems to have worked. mkv and mp4 files now are listed as AVC when played back on the tele.
1 more question over time do device profiles get added to WMS or updated. I am looking at getting the Sony BDV-E370 Blu-ray Home Theatre Kit. This i beleive does support DivX/MKV/MP4 video files over DLNA. So was wondering what would be the best device to assign to it. Or would i have to use the Sony profile for this as well
thanks Mike
thanks Mike
Device type "WD TV Live HD Media Player" or "Samsung TV" or change embedded file support for Sony TV (Settings-Device)mikek wrote: 1 more question over time do device profiles get added to WMS or updated. I am looking at getting the Sony BDV-E370 Blu-ray Home Theatre Kit. This i beleive does support DivX/MKV/MP4 video files over DLNA. So was wondering what would be the best device to assign to it. Or would i have to use the Sony profile for this as well
silencer1979
- Contact:
Hi, i just got the Sony BDV-E370 but i'm not sure who to set up die dlna server in order to stream mkv.
He even does not play/find mp3 files
Is there a how to or something else?
Oliver
Oliver
What program version ?silencer1979 wrote: i just got the Sony BDV-E370 but i'm not sure who to set up die dlna server in order to stream mkv.
Oliver
silencer1979
- Contact:
the newest one
1.02
What is the problem with mp3-files?silencer1979 wrote:the newest one1.02
silencer1979
- Contact:
well, after adding the folder in settings, he seems to find nothing, empty.
//got mp3s working now. lets switch to mkv (h.264) support
Settings-Device-"Embedded file support", add mkvsilencer1979 wrote:well, after adding the folder in settings, he seems to find nothing, empty.
