MKV with Flac
MKV with Flac
I can't play any of my MKV files that use flac as the audio codec. I am pretty much using the default PS3 settings. Can you offer some advice on getting my settings working with flac?
Re: MKV with Flac
Try update on version 0.73.4 (or 0.73.8) http://www.wildmediaserver.com/forum/vi ... &f=3#p1623.abogdonov wrote:I can't play any of my MKV files that use flac as the audio codec. I am pretty much using the default PS3 settings. Can you offer some advice on getting my settings working with flac?
Re: MKV with Flac
Awesome! That did the trick. thanks very much for your help. This is easily the best media server I have tried.Eugene wrote:Try update on version 0.73.4 (or 0.73.8) http://www.wildmediaserver.com/forum/vi ... &f=3#p1623.abogdonov wrote:I can't play any of my MKV files that use flac as the audio codec. I am pretty much using the default PS3 settings. Can you offer some advice on getting my settings working with flac?
