Version 0.71.1 (viewtopic.php?p=102#p102) adds the possibility of localizing the program with the help of automatic translation Microsoft Translate (http://www.microsofttranslator.com)
Supported languages Microsoft Translate
Arabic
Bulgarian
Czech
Chinese Simplified
Chinese Traditional
Danish
Dutch
English
Finnish
French
German
Greek
Hebrew
Italian
Japanese
Korean
Polish
Portuguese
Russian
Spanish
Swedish
Thai
Double click, select all rows with Shift + cursor keys
If while translate of all rows was error, please select a smaller number of rows.
Localization program
Re: Localization program
Works fine with German, a lil bit sticky but in some blocks is possible to translate
can i use the Translation on another Computer?
greetings
greetings
Yes, you can save (button Save As) selected languages and copy to "?:\Program Files\Wild Media Server\Languages" on another computer, restart program.PoeK wrote:Works fine with German, a lil bit sticky but in some blocks is possible to translate
greetings
Thank you for your question, now others will know how to do it.PoeK wrote:uhmm, so easy![]()
What a wonderful product,
I just have a little problem with the localization on the translation.
The icons in front of the languages are not green so I can not traduce automatically (eg French) with google or bing
What should I do?
What should I do?
Try to update the program on 0.72.2 http://www.wildmediaserver.com/forum/vi ... p=371#p371, perhaps language list is empty.DLOQUET wrote:What a wonderful product,
What should I do?
It works.
Thanks a lot
Thanks a lot
I have a question with localisation:
i lost parameters when i translate ( google or micros.) from us to fr?
- wmds fr.JPG (76.08 KiB) Viewed 107699 times
- wms us.JPG (71.35 KiB) Viewed 107699 times
You can find these translations (Ctrl + F) and remove extra spaces.lecureuil wrote:I have a question with localisation:
