Hulu support
Re: Hulu support
Andrey
Re: Hulu support
Post by Andrey »
It works!!!!
Eugene, could you please explain in couple of words how to add the favorite shows to the separate folder?
For example
http://www.hulu.com/feed/show/3003/episodes
I understand that I can copy and paste in wdf file, but it looks like some tags ( <ItemID> , <ParentID> ) have unique values...
Re: Hulu support
Andrey wrote:It works!!!!
For example
In the main form of the program to choose Hulu, on the right mouse button "Add Podcast", in the Link field to specify the address http://www.hulu.com/feed/show/3003/episodes
Andrey
Re: Hulu support
Post by Andrey »
Oh, that was simple!
Thank you for the great program, it is simply the best DLNA server around.
Andrey
Re: Hulu support
Post by Andrey »
'Feature not available with this content' message on TV when I'm trying to pause the video.
Is it possible to fix this?
Re: Hulu support
Andrey wrote:'Feature not available with this content' message on TV when I'm trying to pause the video.
http://www.wildmediaserver.com/forum/vi ... 1624#p1624
Andrey
Re: Hulu support
Post by Andrey »
Thank you, Eugene.
There is another problem: the same podcast sometimes plays, sometimes does not. Test transcoding of the same podcast sometimes works, sometimes does not. When it does not work there no rtmpdump.exe process. I attached the transcoding window.
surfingsmurf
Re: Hulu support
Post by surfingsmurf »
You're the MAN!!! :P Patience paid off... :P
Only problem I can't seem to get it to play anything. I keep getting "video file cannot be played". I'm running the latest update.
Thanks again Eugene
Re: Hulu support
Andrey wrote: There is another problem: the same podcast sometimes plays, sometimes does not. Test transcoding of the same podcast sometimes works, sometimes does not. When it does not work there no rtmpdump.exe process. I attached the transcoding window.
Hulu changes the addresses of servers, possibly some not supported. If let me know address the video page, then I can check.
Re: Hulu support
surfingsmurf wrote: Only problem I can't seem to get it to play anything. I keep getting "video file cannot be played". I'm running the latest update.
Maybe solution http://www.wildmediaserver.com/forum/vi ... 1624#p1624
