i have a mkv 1080p file.
if i don't transcode it, my tv can read the video but not the sound.
if i transcode the file using the "Movies (primary)_1920x1080" profile, my computer isn't fast enought (i've tried others profiles but the problem is the same).
is it possible to transcode sound only in order to send to the tv :
the original video with the transcoded sound?
transcoding sound only
Re: transcoding sound only
Transcoding profile "Movies - TsMuxer"ethanparker wrote:i have a mkv 1080p file.
ethanparker
tsmuxer works like shit, i've tried the differents tsmuxer profiles but the video never follow the sound.
i've even tried to use the tsmuxer script with other programs and the result is always the same so i guess that the problem come from the script (the transcoding parameters).
Have you find a solution ? need to modify the ts-muxer profile ?
Posible problem and solution http://www.wildmediaserver.com/forum/vi ... f=19&t=354
