First, sorry for my english, i am french speaking. I use WMS last version and i try to view a movie with subs. First I try to use CPL between my WDTV Live and my server. It was impossible to see anything. I though it was the link between both, so i change my mind and i've installed a ethernet cable (CAT5E). Now its a bit more fast, but the video is choppy and it's impossible to watch the movie. I guess my problem is linked with transcoding. How can i resolve this? I try to test the transcoding, and the results is attached to this. Could you help me please?
Thanks a lot.
Mike
choppy video while transcoding
- wms1.jpg (128.25 KiB) Viewed 12307 times
Re: choppy video while transcoding
Any idea? Subs are really important for me...
I have no problem with watching movies on WDTV Live when turned on subtitles. The problem may be in link WDTV Live - TV, TV may require the frame rate 25, it can be set in the program settings (Settings-Transcoder-Codecs, frame)
hi Eugene, tks for your reply. Is it possible my problem is in relation with firmware upgrading? I upgraded 3 days ago. 2 weeks ago, it seemed to be running well...
My firmware 1.02.21, WMS - 0.73.4mhendel wrote:hi Eugene, tks for your reply. Is it possible my problem is in relation with firmware upgrading? I upgraded 3 days ago. 2 weeks ago, it seemed to be running well...
ok thanks i will check. Thanks.
Well i've checked the versions, and i have the same than you have (both WMS et WDTV). I have also a PS3, and when i test the same movie with the same subs, it works!! With the WDTV, the movie begins normally, and after 20 Seconds, it begins to be very very slow, like a replay in a football game. I really dont know what i have to do, and its very frustrating, especially when it works with one another device like my PS3. What am i missing?
Thanks for your help,
Mike
Mike
I repeated a problem, it started after a while, I think the problem with the creation MPEGTS stream. Helps choose a different file format transcoded MPEG (DVD) or use the profile transcoding Movies - TsMuxer.mhendel wrote:Well i've checked the versions, and i have the same than you have (both WMS et WDTV). I have also a PS3, and when i test the same movie with the same subs, it works!! With the WDTV, the movie begins normally, and after 20 Seconds, it begins to be very very slow, like a replay in a football game. I really dont know what i have to do, and its very frustrating, especially when it works with one another device like my PS3. What am i missing?
excuse me but how do you do this?
File format - Settings-Transcoder-"Codecs,frame" or Settings-Server-"Individual settings client device"-Transcoding.mhendel wrote:excuse me but how do you do this?
Choosing transcoding profile by right click mouse in list of films.
