Hi All,
I have just installed this, and I can get my Sony KDL32-W5500 to recognise the server but not display any files, when I check the server diagnostics on the TV, it shows WMS "Failed" when I look at the error, ot says "No Compatible File Type found" ... any suggestions welcomed... I am sure I am doing something obviously wrong ...
No Compatible File Type Found
dreamingbadger
Re: No Compatible File Type Found
Doh set DNLA to version 1.5 seems to have it working
dreamingbadger
BTW bloody good App! saved me having to manually re-image a bunch of files!
I too just installed WMD v1.0 and get the same results and message on the HDTV.dreamingbadger wrote:Doh set DNLA to version 1.5 ...
Can you give me a tip as to how to set DNLA to version 1.5? Is it another download?
Settings > Type > I selected (D-Link 320 (DNLA, 16:9, 720x406) because it does not list D-Link 655.
Kerry
Windows 7 Home Premium
D-Link 655 (Cat-6 wired)
Sony 40” 40Z4100 Bravia LCD HDTV
Update:
I found out how to change the DNLA from 1.0 to 1.5.
Now when I check the server diagnostics on the TV I get WMS successful. However when I select Sony's PC mode and play some music or a video on the PC I get "No signal...."
I'm using using Windows Media Player.
Suggestion please,
Kerry
Suggestion please,
Kerry
