I just bought a Bravia KDL-32EX308. I have Wild Media Server up and running and transcoding into MPEG2. However, the results look a bit blocky. After upping the bit rate to 6Mbit, it looks quite a bit better.
However, the TV also supports streaming in AVCHD. Is there a way to transcode to AVCHD using Wild?
I have a quad core 3.0GHz processor in my PC, so it has some muscle for transcoding. MPEG2 barely even moves the CPU meter.
Transcode to AVCHD to KDL-32EX308
Re: Transcode to AVCHD to KDL-32EX308
I have the same TV. I do not think it has enough power to decode high bitrate AVCHD video. MPEG2 at 8mbps works great for me. Before I installed the WMS (and after terrible results with WMP12), I tried to use Cyberlink encoded AVCHD via USB, and the video playback was jerky.
Even lower bitrate AVCHD would be better than MPEG2 in a lot of circumstances.
I played back a relatively low bitrate H264 mp4 last night via USB and it looked fantastic. Much less noise than the MPEG2 transcodes I've seen. No macroblocking, either.
AVCHD also uses H264.
What a deal for this TV, eh?
Yes, a lot of bang for the buck.
It would be even better if Sony was not so picky about format of the files it can play.
You can change the profile for transcoding H264-coding, but the rate of transcoding is greatly reduced.
Settings-Transcoder-Codecs-Frame - choose file format MPEGTS
Settings-Transcoder-Profiles - Movies (additional) - Copy - Movies (additional)_1 - Edit
OK-OK-OK
On the right mouse button you can select the new transcoding profile, and perform a test transcoding, pay attention to the speed transcoding (fps), it should be more framerate.
For HD-movies with a standard size frame you can use a transcoding profile Movies - TsMuxer, it does not change the video stream.
function GetVideoCodec(const aVideoCodec: string): string;
if (aVideoCodec = '') or SameText(aVideoCodec, 'MPEG2') then
Result := 'libx264'
else if SameText(aVideoCodec, 'WMV') then
Result := 'wmv2'
else
Result := aVideoCodec
Hmm, tried that, but got a blank screen when I tried to stream.
Is MPEGTS equivalent to the AVCHD container?
Encoding for a 25fps 720p video was around 27fps for a 720x406 output, which seems marginal to me. All 4 cores were screaming, too. Is there a way to adjust whether the encode is optimized for speed or quality?
http://en.wikipedia.org/wiki/AVCHDShapeGSX wrote:Hmm, tried that, but got a blank screen when I tried to stream.
