after deciding to re-encode my video files into MP4 files for support a wider range of playback-clients, I came to this point to test my transcoded files on my Samsung TV (LE32B650). The server used WMS 0.73 version and my MP4-file contains an H.264 (AVC) and the audio-data is AAC 5.1 encoded.
The problem is, that my TV doesn'z support my mp4 file when I want to watch it with WMS. But it works, when I put that file onto my USB-Disk and play it directly from USB. I hope that the transcoding isn't here the problem because the TV understands the RAW-data.
Where is problem here, that my Samsung doesn'z support playback via WMS?
Thanks for help.
MP4 - Playback
Re: MP4 - Playback
These files work with the PC Share Manager?adgen wrote: after deciding to re-encode my video files into MP4 files for support a wider range of playback-clients, I came to this point to test my transcoded files on my Samsung TV (LE32B650). The server used WMS 0.73 version and my MP4-file contains an H.264 (AVC) and the audio-data is AAC 5.1 encoded.
Re: MP4 - Playback
Hi Eugene,Eugene wrote: These files work with the PC Share Manager?
I've tried PC Manager with my own files: Same result.
The funny thing is, I have another mp4 file with AAC encode audio and it works on WMS. Only my file make some trouble. I post the media information obtained from WMS.
Old MP4-File (works with WMS)
Property name/value | |
- | General |
| | Complete name: D:\Old MP4-File.mp4
| | Format: MPEG-4
| | Format profile: Base Media / Version 2
| | Codec ID: mp42
| | File size: 999 MiB
| | Duration: 1h 50mn
| | Overall bit rate: 1 269 Kbps
| | Encoded date: UTC 2008-02-18 02:51:10
| | Tagged date: UTC 2008-02-18 04:07:57
- | Video |
| | Format: AVC
| | Format/Info: Advanced Video Codec
| | Format profile: Main@L5.1
| | Format settings, CABAC: Yes
| | Format settings, ReFrames: 3 frames
| | Codec ID: avc1
| | Codec ID/Info: Advanced Video Coding
| | Duration: 1h 50mn
| | Bit rate mode: Variable
| | Bit rate: 1 008 Kbps
| | Width: 720 pixels
| | Height: 304 pixels
| | Display aspect ratio: 2.35:1
| | Frame rate mode: Constant
| | Frame rate: 25.000 fps
| | Resolution: 24 bits
| | Colorimetry: 4:2:0
| | Scan type: Progressive
| | Bits/(Pixel*Frame): 0.184
| | Stream size: 794 MiB (79%)
| | Writing library: x264 core 56
| | Encoding settings: cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=5 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=0 / bime=0 / keyint=500 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1008 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
| | Language: English
| | Tagged date: UTC 2008-02-18 04:04:28
- | Audio #1 |
| | Format: AAC
| | Format/Info: Advanced Audio Codec
| | Format version: Version 4
| | Format profile: LC
| | Format settings, SBR: No
| | Codec ID: 40
| | Duration: 1h 50mn
| | Bit rate: 128 Kbps
| | Maximum bit rate: 190 Kbps
| | Channel(s): 2 channels
| | Channel positions: L R
| | Sampling rate: 48.0 KHz
| | Resolution: 16 bits
| | Stream size: 101 MiB (10%)
| | Language: German
- | Audio #2 |
| | Format: AAC
| | Format profile: LC
| | Codec ID: 40
| | Duration: 1h 50mn
| | Bit rate: 128 Kbps
| | Maximum bit rate: 220 Kbps
| | Resolution: 16 bits
| | Language: English
- | Text |
| | Format: Apple text
| | Codec ID: text
| | Duration: 1h 50mn
| | Bit rate mode: Constant
| | Bit rate: 1 bps
| | Stream size: 936 Bytes (0%)
| | Language: English
- | General |
| | Complete name: D:\My own encoded MP4-file.mp4
| | Format: MPEG-4
| | Codec ID: mp42
| | File size: 2.81 GiB
| | Duration: 1h 55mn
| | Overall bit rate: 3 470 Kbps
| | Encoded date: UTC 2010-04-04 19:33:12
| | Tagged date: UTC 2010-04-04 19:33:12
| | Writing application: Yamb 2.1.0.0 [http://yamb.unite-video.com]
- | Video |
| | Format: AVC
| | Format profile: High@L3.0
| | Codec ID: avc1
| | Duration: 1h 55mn
| | Bit rate: 3 000 Kbps
| | Maximum bit rate: 13.7 Mbps
| | Width: 720 pixels
| | Height: 424 pixels
| | Display aspect ratio: 2.469
| | Original display aspect ratio: 2.471
| | Resolution: 24 bits
| | Colorimetry: 4:2:0
| | Bits/(Pixel*Frame): 0.393
| | Stream size: 2.43 GiB (86%)
| | Writing library: x264 core 80 r1376M 3feaec2
| | Encoding settings: cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
| | Language: English
| | Tagged date: UTC 2010-04-04 19:34:28
- | Audio |
| | Format: AAC
| | Format profile: LC
| | Codec ID: 40
| | Duration: 1h 55mn
| | Bit rate: 467 Kbps
| | Maximum bit rate: 529 Kbps
| | Channel(s): 6 channels
| | Channel positions: Front: L C R, Rear: L R, LFE
| | Resolution: 16 bits
| | Stream size: 387 MiB (13%)
| | Title: Deutsch
| | Language: German
| | Encoded date: UTC 2010-04-04 19:34:19
I've read something about problems when using MP4 over DLNA. Do you have an idea?
Cheers.
Re: MP4 - Playback
Ok, I think the problem is the resolution of my MP4 file. As mentioned in this article (http://gxben.wordpress.com/2008/08/24/w ... l-so-much/) when the dimension exceeds 720×576, MP4 isn't a propper container format for DLNA any more. In this case MPEG-TS should be the right solution.
So I've muxed my video (h.264) and audio (ac3) data into *.m2ts file and test it with WMS. The result: My video file was not discard by my Samsung TV. But: I've had some problems with the sound. At the beginning I can hear some pieces of the soundtrack followed by silence
Only with a TSMuxer profile, audio is working. But I would avoid Transcoding on the fly.
imocattivo
Re: MP4 - Playback
use mkv as container, i've resolved with this method.
