In version 0.73rc1 (viewtopic.php?p=1018&f=3#p1018) added possibility to use custom structure of media resources.
File structure of media resources in Samsung archive:
Actions:
1. Unarchive the attached file (file SamsungDCM10.wdf)
2. Settings-Device-"Thumbnails, identifiers - Identifiers media resources - click on the "Structure of media resources."
3. Select row Media in the left part of the form.
4. On the right-button mouse - "Load from file" - choose SamsungDCM10.wdf.
5. Ok-Ok
6. Restart server.
If the connection will be problems, then to restore the work to clear the individual structure in the form of editing (the Clear button).
P.S. If you use individual settings for the device, then load the structure should be in them.
						Support structure of media resources Samsung
				imocattivo
Re: Support structure of media resources Samsung
not work.
but i'm very interested in this.
At what stage the problem?imocattivo wrote:not work.
				imocattivo
wen i try to connect the tv it's  show the new menu but appear a message that say tha t the media server is not ready and the sistem return to the beginning.
if i reset WMS to default the connection with the TV is ok
i've installed the last build RC2.
n.b. sorry for my english, i'm italian...
Settings-Additional you can enable debug log, in same place you can save log file, analyze by yourself, attach to the forum in the archive or send it to support@wildmediaserver.comimocattivo wrote:wen i try to connect the tv it's show the new menu but appear a message that say tha t the media server is not ready and the sistem return to the beginning.
				imocattivo
i've send you the log file.
Thanks, there are problems, television requests services that are not implemented in the program. I will announce when it will be possible.imocattivo wrote:i've send you the log file.
				imocattivo
ok thanks. i'm waiting
Update on test version 0.73.1 (0.73-0.73.1)
1. Settings-Transcoder-codecs, frame-Audio:
- To the list of codecs added LPCM, is used in the profile transcoding
"Movies - TSMuxer", "Movies - DirectShow - TSMuxer".
- added mode "Hide DTS in LPCM", can be used if
media device is connected to the receiver (DTS 5.1 (768 kbit, 1536kbit)) (not tested).
2. Changes in support of the work with Samsung TVs
(http://www.wildmediaserver.com/forum/vi ... ?f=9&t=154). (not tested).
				imocattivo
Same problem
i've send you the new log file.
if you need something tell me, i'm hear for testing your solution.
