How to pre-transcode files?
pavel
Post by pavel »
Hi!
I try to pre-transcode a file with Shift+F5, but I get an error every time (screenshot).
How to make pre-transcoding work?
TV = Sony W5500
Script text:
  csDestDirectory   = 'D:\video\_transcoded';                                  // directory transcoded files
  csTranscodingProfileName = 'Фильмы (основной)';           // transcoding profile name (Movies (primary))
  mpiTranscodingFinish = 100000;  // Id properties "Sign complete transcoding"
                                  // Properties less than 100000 are used by the program
procedure ProcessFile(const aSourceFileName, aDestDirectory: string; aCheckTranscodingFinish: Boolean);
  bExecuteTranscoding: Boolean;
  MediaItem: TWmsScriptMediaItem;
  sDestDirectory, sDestFileName, sDestFileExt, sLogMessage: string;
  if WmsFileMediaType(aSourceFileName) = mtVideo then begin
    if not WmsFileLocked(aSourceFileName) then begin
      sDestFileExt := WmsGetTranscodingFileExt(csTranscodingProfileName);
      sDestFileName := IncludeTrailingBackslash(aDestDirectory) +
               ChangeFileExt(ExtractFileName(aSourceFileName), sDestFileExt);
      if not WmsFileLocked(sDestFileName) then begin
        bExecuteTranscoding := True;
        if aCheckTranscodingFinish then begin
          MediaItem := WmsFindMediaItemByFileName(sDestFileName);
          if (MediaItem <> nil) and (MediaItem.Properties[mpiTranscodingFinish] = '1') then begin
            if FileExists(sDestFileName) then
              bExecuteTranscoding := False
            else begin
              MediaItem.Properties[mpiTranscodingFinish] := '0';
              WmsDatabaseAutoSave
        if bExecuteTranscoding then begin
          sLogMessage := 'Processing media resources: %s transcoding file "' + aSourceFileName + '" to file "' + sDestFileName + '"';
          WmsLogMessage(mtiInfo, Format(sLogMessage, ['Start']));
          if WmsFileTranscoding(aSourceFileName, sDestFileName, csTranscodingProfileName) then begin
            if MediaItem = nil then
              MediaItem := WmsCreateMediaItem(sDestFileName);
            if MediaItem <> nil then
              MediaItem.Properties[mpiTranscodingFinish] := '1';
            WmsDatabaseAutoSave;
            WmsLogMessage(mtiInfo, Format(sLogMessage, ['Finish']), True);
          end else
            WmsLogMessage(mtiError, Format(sLogMessage, ['Error']))
  ProcessMediaResult := False;
  if csDestDirectory = '' then
    RaiseException('Not specified directory transcoded files.')
  else if csTranscodingProfileName = '' then
    RaiseException('Not specified transcoding profile name.')
  else begin
    MediaItem := WmsCurrentMediaListItem;
    if MediaItem <> nil then begin
      ProcessFile(MediaItem.Properties[mpiFilePath], csDestDirectory, False);
      ProcessMediaResult := True
    end else
      RaiseException('No current media resource')
Re: How to pre-transcode files?
pavel wrote: I try to pre-transcode a file with Shift+F5, but I get an error every time (screenshot).
TV = Sony W5500
Script text:
            else begin
              WmsDatabaseAutoSave
          end else
  else begin
    end else
Test transcoding is working with the selected profile for the problematic file?
pavel
Post by pavel »
Yes, test transcoding works perfectly ok.
The file is not problematic, I can't decode any file in my collection. At the same time, there is no problems when I watch these files on TV using WMS.
pavel wrote:Yes, test transcoding works perfectly ok.
In editing the script can be done step by step execution.
pavel
Post by pavel »
Step-by-step execution doesn't help. I can't set the "WmsCurrentMediaListItem" in steb-by-step mode. See attachment.
Anyway, this standard script doesn't work for me - the "WmsFileTranscoding(aSourceFileName, sDestFileName, csTranscodingProfileName)" returns "False" without any comment.
