I hace a KDL-46HX700 TV, and I just installed WMS, pictures & music runs right, but I have problems with movies, some are working but the rest I can see the name on the tv but TV can't play it. Usually I can see MPG format, nut not avi files & H264 codec.
I've tried this movies with playon and run right, but woth playon music & images doesn't work
Thanks for your help
sony KDL-46HX700
Re: sony KDL-46HX700
Select the configuration of the device "Sony TV NTSC (DLNA, 16:9, 720x406)"molby wrote:
thanks eugene,
I'll try this afternoon
Regards
Regards
It doesn't work.
I don't understand, music, images & some movies are ok, but some movies doesn't work but i can see the name of the file on tv.
Do i need to change something on settings?
Tried to look through the folder Transcoding?molby wrote:It doesn't work.
ok Eugene.
But the first movie I tried is not working, i'll try with more files.
It must be a settings issue because with playon I can see all the movies I have on the PC.
Thanks from Spain
Thanks from Spain
In what frame size you can see all the movies?molby wrote:ok Eugene.
Trascoding is not working but I still can see the names of the files on TV. The frame size in WMS is 720x406 & is put to minimum, proportional to the screen
With PlayON I can see all the movies but I don't know how to find the frame size?
Thanks for you help
Thanks for you help
The files that I can see are MPEG1VIDEO Codec
Files that don't work have this CODEC;
MPEG4(DIVX)
MPEG4(XDIV)
MPEG4
H264
But all the files appear on my TV Screen
Thanks again
MPEG4(DIVX)
MPEG4(XDIV)
MPEG4
H264
Thanks again
On the right-button mouse in the list of films you can perform a test transcoding, screenshot, please. What information is shown on TV about video media resources ?molby wrote:The files that I can see are MPEG1VIDEO Codec
MPEG4(DIVX)
MPEG4(XDIV)
MPEG4
H264
Thanks again
