WMS for Sony Bravia 52XBR9
Hi all,hapy new year,any help to set-up my Sony 52XBR9 with WMS.Now I only geting <Compatible files lould not be found> in Media server Troubleshooting. Thanks!
Re: WMS for Sony Bravia 52XBR9
Hi,Val wrote:Hi all,hapy new year,any help to set-up my Sony 52XBR9 with WMS.Now I only geting <Compatible files lould not be found> in Media server Troubleshooting. Thanks!
I think here you will find a solution to the problems
viewtopic.php?f=3&t=16
Hello, thanks for the respond, I tried all directions of the topic viewtopic.php?f=3&t=16 with no success.
I ting my problem is in the setting of the WMS at all. The TV sees the server as inactive icon for all pictures, music and videos. I tried Windows, Twonky and Nero Media servers and they worked normal.
Follow attaching the current settings:
- Show_3.png (58.82 KiB) Viewed 23820 times
- Show_2.png (51.57 KiB) Viewed 23820 times
- Show_1.png (55.53 KiB) Viewed 23820 times
Remove the registration WMS in the TV. In the setup program on the page Server specify a permanent server port from 1024 to 65535, then restart the server.Val wrote:Hello, thanks for the respond, I tried all directions of the topic viewtopic.php?f=3&t=16 with no success.
I delited the server from TV list of survers,set the port to 2000 ,restart the server,updated the surver list in TV,WMS does not appier on list animore.
In the Internet viewer open http://server_ip_address:2000 should open the presentation, if does not open, then the server closed firewall.Val wrote:I delited the server from TV list of survers,set the port to 2000 ,restart the server,updated the surver list in TV,WMS does not appier on list animore.
Never mind,I got pictures and music, but not any video.There are lots of folders and subfolder in video mode with <there are no items to disply>,I may need to fix the transcoding now.
Thans agein,that was a big step forward.
In version 0.71.1 added device configuration "Sony TV NTSC ((DLNA), 16: 9, 720x406)", try upgrading program and select the device type "Sony TV NTSC ((DLNA), 16: 9, 720x406)" (http://www.wildmediaserver.com/forum/vi ... =7&start=0).Val wrote:Never mind,I got pictures and music, but not any video.There are lots of folders and subfolder in video mode with <there are no items to disply>,I may need to fix the transcoding now.
It works, Thanks alot (mnogo blagodaria),
Hi, I've update wms to 1.71 version, but i can't see the device "Sony TV NTSC (DLNA, 16:9, 720x406)", in the dlna device list.
Help me please, and sorry for my english, but I'm italian... thanks.
