Re: Changing playback container and audio format on one file
Posted: Mon Feb 07, 2011 11:57 am
drem wrote:What is the easiest and quickest way of changing the playback properties of a file? For example, I mostly run .mkv files and do so through the mkv container, but there is one particular movie file that will not play unless through the .mpeg container. This file plays when I use the Playstation 3 default profile and it was displayed as .mpeg.
I use the Oppo BDP-93 and created a new DNLA profile for it with the ability to play most formats available. However, when doing so, the above mentioned movie file does not play.
Choose a playback via the folder Transcoding
