Page 1 of 2
PODCAST Problems
Posted: Sun Jan 30, 2011 12:42 pm
by morefield
Dear Eugene,
I am using the Uitzendingemist (7 days Beta) podcast.
It works fine until after 2 minutes it suddenly stops playing on my Sony Bravia TV (700EX). This happens over and over again. On IE these programs work flawles.
Could you please be so kind to tell me what is wrong and how to fix this?
Morefield
Re: PODCAST Problems
Posted: Sun Jan 30, 2011 1:27 pm
Settings - Transcoder - Profiles - "Internet-television" - Edit -
"Terms of use" - delete mpInternetItem - Ok - Ok - Ok
Folder "Uitzending Gemist" - right click - "Edit title" - "Transcoding
profile" - "Internet-television"
Posted: Sun Jan 30, 2011 1:52 pm
by morefield
Thanks for the quick response.
Made the changes you suggested, but still every item stops after app. 2 minutes. Can you check it once more?
Posted: Sun Jan 30, 2011 2:02 pm
morefield wrote:Made the changes you suggested, but still every item stops after app. 2 minutes. Can you check it once more?
What's the address of the page?
Posted: Sun Jan 30, 2011 2:06 pm
by morefield
Posted: Sun Jan 30, 2011 2:13 pm
Posted: Sun Jan 30, 2011 2:17 pm
by morefield
No, if I play the link on my computer there are no problems. But if I play it from my tv, via the menu of WMS, every single item quits after two minutes.
Posted: Sun Jan 30, 2011 4:04 pm
by morefield
Hopefully you can try to solve it?
Posted: Sun Jan 30, 2011 7:12 pm
morefield wrote:No, if I play the link on my computer there are no problems. But if I play it from my tv, via the menu of WMS, every single item quits after two minutes.
Test transcoding with "Internet-television" ?
Posted: Sun Jan 30, 2011 7:13 pm
morefield wrote:Hopefully you can try to solve it?
I have no problems with playback.
