individual FPS setting per movie
Posted: Fri Jan 07, 2011 9:39 pm
by fleggy
Hello. Is it somehow possible to have individiual FPS setting for each movie? My HD movies have 23.976FPS but DVD ISOs have typically 25FPS. I have to change FPS in transcoder setting according to the source because if input and output FPS are not equal then the playback is not smooth. It is very uncomfortable but I believe that there is a way how to solve this. Thanks
Re: individual FPS setting per movie
Posted: Sat Jan 08, 2011 7:33 am
fleggy wrote:Hello. Is it somehow possible to have individiual FPS setting for each movie? My HD movies have 23.976FPS but DVD ISOs have typically 25FPS. I have to change FPS in transcoder setting according to the source because if input and output FPS are not equal then the playback is not smooth. It is very uncomfortable but I believe that there is a way how to solve this. Thanks
0 for input FPS.
Posted: Sat Jan 08, 2011 9:05 am
by fleggy
Sorry, I'm not sure where. Transcoder settings: 23,976. My DVD ISO is 25 FPS. I set 0 FPS in Edit information on Cell 00. But it doesn't work. The movie is jerky and Test transcoding still shows:
Input #0, mpeg, from '\\.\pipe\7787B399320E40CC8C53E5AE14495074':
Duration: N/A, start: 0.287267, bitrate: 10568 kb/s
Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], 9800 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
Stream #0.2[0x81]: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
Output #0, dvd, to 'e:\temp\WmsTemp\Test_0eb4746e97e7d587961bb8f651103ad4.mpg':
: Video: mpeg2video, yuv420p, 1920x1088 [PAR 136:135 DAR 16:9], q=2-31, 10000 kb/s, 90k tbn, 23.98 tbc
: Audio: libmp3lame, 48000 Hz, 2 channels, s16, 320 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
frame= 553 fps= 74 q=1.6 size= 12118kB time=22.80 bitrate=4354.0kbits/s dup=0 drop=23
