vob files transcoded: Why ?
Posted: Tue Dec 21, 2010 12:54 am
by libero
My Samsung UE40B7000 can view vob files from dvd not transcoded. I made a try using "*" in the supported media type.
But if i do not set "*" then the vob file is transcoded. Why, what setting i have to change to avoid transcoding ?
The vob extension in settings-server-my tv-settings-file types is correct without any transcode setting.
libero
Re: vob files transcoded: Why ?
Posted: Tue Dec 21, 2010 8:06 am
libero wrote:My Samsung UE40B7000 can view vob files from dvd not transcoded. I made a try using "*" in the supported media type.
Perhaps selected a transcoding profile
