How to change language at DVD
Posted: Thu Dec 02, 2010 8:50 pm
by lizi0
Sorry for my english ..
My question is how to change the language of video playback in DVD format. I have a movie with the extension vob. the original soundtrack is in English, I would like to change it to Polish (this is available - on the DVD player on my computer I can change the language.) The transcoding settings I set the default language subtitles on the PL and the default audio track on the UK.
I am using WMS to play movies from an external drive so I have built database (often unplug the drive.) The only way to change the language that I discovered how to play using the transcoding option, however, then there is a problem with automatic switching to next video file.
Re: How to change language at DVD
Posted: Sun Dec 05, 2010 7:22 am
lizi0 wrote: My question is how to change the language of video playback in DVD format. I have a movie with the extension vob. the original soundtrack is in English, I would like to change it to Polish (this is available - on the DVD player on my computer I can change the language.) The transcoding settings I set the default language subtitles on the PL and the default audio track on the UK.
Via folder Transcoding you can to select a audio track.
Posted: Mon Dec 06, 2010 6:47 am
by lizi0
Yes I know but,
When I select one part of the dvd movie and select my language and after finish this part i must bact to menu and choose next one part, select language.... That is so inconvenient...
Any other ideas
