Page 1 of 2
Re: Dailymotion/Metacafe support
Posted: Tue Feb 02, 2010 1:12 pm
cmk001 wrote:Thanks for such a nice programme, youtube is working now. Will appreciate if we can connect to Dailymotion and Metacafe Videos.
Version 0.72.2
Settings - Transcoder - Profiles - Add
Name: Podcasts (Metacafe,DailyMotion)
Execute mode: Transcoding
Language: PascalScript
Transcoding parameters:
function HTTPDecode(const AStr: string): string;
  C, R: Char;
  Result := ''; i := 1;
  while i <= Length(aStr) do begin
    C := aStr[i];
    R := #0;
    if C = '+' then
      R := ' '
    else if (C = '%') and (i < Length(aStr)) then begin
      Inc(i);
      C := aStr[i];
      if C = '%' then
        R := '%'
      else begin
        R := Chr(StrToIntDef('$' + Copy(aStr, i, 2), 0));
        Inc(i)
    end else
      R := C;
    if R <> #0 then
      Result := Result + R;
    Inc(i)
function SearchLink(const aText, aRegEx: string; var aMatch: string): Boolean;
  with TRegExpr.Create(aRegEx) do try
    Result := Search(aText);
    if Result then
      aMatch := HttpDecode(Match)
  finally
    Free
function SearchSize(const aText, aRegEx: string; var aWidth, aHeight: Integer): Boolean;
    if Result then begin
      aWidth  := StrToIntDef(Match, 0);
      aHeight := StrToIntDef(Match(2), 0);
  finally
    Free
function SelectDailyMotionLink(const aLink: string): string;
  sLink, sBestLink, sCurLink: string;
  i, iWidth, iHeight, iBestFrameSize: Integer;
  sLink := aLink; sBestLink := '';
  iBestFrameSize := 0;
  while sLink <> '' do begin
    i := Pos('||', sLink);
    if i > 0 then begin
      sCurLink := Copy(sLink, 1, i - 1);
      sLink := Copy(sLink, i + 2, Length(sLink))
    end else begin
      sCurLink := sLink;
      sLink := ''
    if SearchSize(sCurLink, 'FLV-(\d*)x(\d*)', iWidth, iHeight) or
       SearchSize(sCurLink, 'H264-(\d*)x(\d*)', iWidth, iHeight) then begin
      if iBestFrameSize < iWidth * iHeight then begin
        iBestFrameSize := iWidth * iHeight;
        sBestLink := sCurLink;
    if sBestLink = '' then
  Result := sBestLink
  sLink, sPage, sTranscoderParams: string;
  sPage := WmsDownloadURL(InputFileName); sLink := '';
  if Pos('http://www.metacafe.com', LowerCase(InputFileName)) > 0 then begin
    SearchLink(sPage, 'mediaURL=(.*?)&postRollContentURL', sLink)
  end else if Pos('http://www.dailymotion.com', LowerCase(InputFileName)) > 0 then begin
    if SearchLink(sPage, 'addVariable\("video", "(.*?)"', sLink) then
      sLink := SelectDailyMotionLink(sLink)
  if sLink <> '' then begin
    sTranscoderParams := WmsTranscodingProfileParams('Movies (primary)') + ' "<OUTPUT FILE>"';
    TranscodingResult := WmsTranscodingExecute('WMSMPEG', sTranscoderParams, True,
                                 WmsDownloadURLToPipe(sLink), OutputFileName)
  end else
    TranscodingResult := False
Choose profile transcoding "Podcasts (Metacafe, DailyMotion)" on the right-button mouse for selected podcasts.
Posted: Thu Feb 04, 2010 9:30 am
cmk001 wrote:Thanks for fast reply, but not working on any link from Dailymotion or Metacafe. In monitor panel data line stays white and does not change colour to green.
For example ?
Posted: Thu Feb 04, 2010 12:52 pm
cmk001 wrote:Please check this link http://www.dailymotion.com/video/x9xi72 ... irgini_fun
error log.
16:12:32:470 Sender: TWmsTranscodingItem.GetTranscodingCommandLine
?Podcasts (Metacafe,DailyMotion)
16:12:32:470 Sender: TWmsTranscodingItem.StartTranscoding
Enter: C:\wmmm\WmsTemp\Test_7243a503b7feb9b3e6b09cdc0743ca1e.mpg
16:12:32:471 Sender: TWmsTranscodingItem.StartTranscoding
Leave: C:\wmmm\WmsTemp\Test_7243a503b7feb9b3e6b09cdc0743ca1e.mpg, Result: 0
16:12:32:471 Sender: TWmsTranscodingItem.TranscodingFinish
TranscodingID: 655bcdbe566aa660e41d3968170e8f6e, TranscodingState: Stopped
16:13:19:759 Sender: TWmsTranscodingItem.GetTranscodingCommandLine
16:13:19:759 Sender: TWmsTranscodingItem.StartTranscoding
Enter: C:\wmmm\WmsTemp\Test_09b597cf875cb3d646ad33bde0a83cba.mpg
16:13:19:759 Sender: TWmsTranscodingItem.TranscodingFinish
TranscodingID: 9033208d9dce6eb1c302096080f5dbd0, TranscodingState: Stopped
16:13:19:760 Sender: TWmsTranscodingItem.StartTranscoding
Leave: C:\wmmm\WmsTemp\Test_09b597cf875cb3d646ad33bde0a83cba.mpg, Result: 0
Test transcoding works? (video 11 sec)
Posted: Fri Feb 05, 2010 12:00 pm
cmk001 wrote:After selecting Test Transcoding, a white data line in monitor panel shows but cmd window does not pop up to show progress of transcoding.
If you perform (green button) transcoding profile from editing (Settings-Transcoder-Profiles), then the problem exists?
Posted: Fri Feb 05, 2010 8:43 pm
cmk001 wrote:I checked it, Message window says: Execution error: The URL does not use a recognized protocol
Before you begin, make the current testing resource in the list of films
Posted: Sat Feb 06, 2010 3:08 pm
cmk001 wrote:Yes green check button in profiles gives Results: true but in Podcast-List movies , Yest Transcoding not working for example please try this link.
http://www.metacafe.com/watch/4126505/a ... eaturette/
After copying the transcoding profile name from the forum, the profile may have invalid name (two line), try to set the profile name manually.
http://www.metacafe.com/watch/4126505/a ... featurette - no any problems
Posted: Tue Mar 02, 2010 4:02 pm
cmk001 wrote:Everything was working fine but suddenly Dailymotion is not working, Metacafe is OK. Test script/Test Transcoding also fails. Please advise.
http://www.dailymotion.com/rss/ - no problem
Posted: Fri Mar 05, 2010 2:06 pm
cmk001 wrote:Is it possible to create a sub-folder under Podcasts and then assign a Transcoding profile to that sub-folder so that all podcasts in that sub-folder are handled by that Trancoding profile. Now I have to allocate same Trancoding Profile to each podcast seperately.
You can select multiple podcasts and set them to profile transcoding. Profile transcoding for a folder is added to future versions.
Posted: Wed Mar 17, 2010 7:42 am
cmk001 wrote:A small problem. After upgrade to version 0.73 Podcast for Metacafe is transcoding well but Dailymotion is not working, even Test Trancoding is not working for Dailymotion, it is timed out and monitor window does not open.Please help.
Posted: Sat Apr 17, 2010 10:37 am
cmk001 wrote:Thanks for New Podcast changes in version 0.73.4. But my old Podcasts under my own Profile "Podcast-Daily Motion Metacafe" is no more working, please help.
Daily Motion - http://www.wildmediaserver.com/forum/vi ... 1635#p1635
Metacafe - http://www.wildmediaserver.com/forum/vi ... 1822#p1822
Drag & drop old podcast feeds to new folders. Change the properties of old feeds, set the inheritance properties of the parent folder.
