LG 55LE8500
amir hezarkhani
Re: LG 55LE8500
Post by amir hezarkhani »
Eugene wrote: WMS: List [Movies] - select a file - right click - "Transcoding profile" - "Movies - TsMuxer" - right click - "Test transcoding" - check playback on TV
Dear Eugene
Thanks for every thing
I followed your instruction and was solved my problem as before :lol:
but 30 SEC after starting of transcoding ,movie was stop and returned to first and played again :o
(my movie is HD in MKV format and DTS sound)
please help me as soon as posissible,as everytime :)
Re: LG 55LE8500
What value in "Terminate transcoding, if the temporary file is not used during ? seconds" (Settings-Transcoder) ?
amir hezarkhani
Re: LG 55LE8500
By default : 30 SEC
Re: LG 55LE8500
By default : 30 SEC
Try to increase this value or disable
amir hezarkhani
Re: LG 55LE8500
By default : 30 SEC
I increased this item to 100 SEC and 50 SEC then I disabled this item, but didn't solve my problem :cry:
Re: LG 55LE8500
By default : 30 SEC
Chunked mode enabled?
amir hezarkhani
Re: LG 55LE8500
By default : 30 SEC
I will check this item :geek:
Re: LG 55LE8500
amir hezarkhani wrote:where is chunk mode location for enabling :geek:
Settings - Device
or
Settings - Server - choose a device - Edit - Settings
amir hezarkhani
Re: LG 55LE8500
Settings - Device
or
No, chuked mode was not enable, I tried both checked and unchecked chunked mode for file and stream (4 state) , but my problem didn't solve.
TV played movie with parasite for 20-30 SEC then stop and play again :x
Tv play this movie correctly without transcoding.
Re: LG 55LE8500
Debug log can be enabled in Settings-Additional. Same place a debug log can be viewed. Examine yourself or attach to the archive on the forum or send to support@wildmediaserver.com.
