Re: Sound and video intermittently out of sync
Posted: Sun Sep 26, 2010 5:10 pm
sysrage wrote:I have been using WMS to stream videos to my Sony KDL-52EX700. Other than some screwy aspect ratio issues I've been fighting with, it works well for the most part. Recently, there have been issues with sound and video intermittently being out of sync when watching a recorded TV show. The show is in xvid/avi format. 90% of the show is synced up properly, but every once in awhile (totally random times) the sound will be ahead of the video. It eventually syncs back up again but is really annoying when it happens. Watching the avi on my computer, the sound and video are always in sync.
There's so many different transcoding settings, so I'm not real sure what to even start with. CPU usage never gets over 55%, so I don't think this is due to my system being overloaded. The TV has a wired connection to my network. Computer running WMS also is wired.
I tried the following transcoding profiles and they all have the same out-of-sync issues:
- Movies (primary)
- Movies (primary)_720x406
- Movies - CoreAVC
- Movies - CorePlayer
I also tried Movies - TsMuxer, but when using that I only get audio. No video is shown.
Media Device is set to Sony TV (DLNA, 16:9, 1920x1080)
Most settings are at their defaults except for my changing Frame size - Format to 4:3 (Minimum, proportional to the screen). This was in attempt to fix the odd aspect ratio issues I mentioned earlier.
Does anybody have any suggestions to help with the audio/video sync problems?
Try to start playback from the first minute through a folder Transcoding. If you do not help, then in the folder Settings can be set to delay the sound.
Posted: Mon Sep 27, 2010 3:38 pm
sysrage wrote:Turning on 'Original Audio' fixes the problem. Is there a setting I can tweak somewhere so it will only transcode the audio if it's an unsupported format?
Settings are not, but you can change the transcoding profiles "Movies (additional)" or "Movies - TsMuxer" for this.
Posted: Tue Sep 28, 2010 12:42 pm
sysrage wrote:
Eugene wrote:Settings are not, but you can change the transcoding profiles "Movies (additional)" or "Movies - TsMuxer" for this.
How would I change the profile so it uses original audio whenever it can?
Settings - Transcoder - Profiles - choose profile - Edit
