using a proxy
Posted: Thu Sep 16, 2010 11:13 am
by isopor
I like watching Iplayer podcasts. But for this, I have to configure my Windows XP to use an UK proxy server.
The problem is that when I do that all my internet browsing will use that proxy.
Is there a way to tell WMS to use an specific proxy instead of relying on system configuration?
Or maybe is there to configure the Windows proxy to be used only for specific destinations/program?
Re: using a proxy
Posted: Thu Sep 16, 2010 7:41 pm
isopor wrote:I like watching Iplayer podcasts. But for this, I have to configure my Windows XP to use an UK proxy server.
You can change IPlayer script (BBC iPlayer-Edit title-Script for the links to the resource-Edit script)
HTTPREQUEST_PROXYSETTING_PROXY = $00000002;
HTTPREQUEST_SETCREDENTIALS_FOR_SERVER = $00000000;
HTTPREQUEST_SETCREDENTIALS_FOR_PROXY = $00000001;
ProxyServer = '127.0.0.1:8000';
ProxyUserName = '';
ProxyPassword = '';
function WmsDownloadURL(const aURL: string): string;
WinHttp: Variant;
WinHttp := CreateOleObject('WinHttp.WinHttpRequest.5.1');
WinHttp.Open('GET', aURL);
if ProxyServer <> '' then begin
WinHttp.SetProxy(HTTPREQUEST_PROXYSETTING_PROXY, ProxyServer);
if ProxyUserName <> '' then
WinHttp.SetCredentials(ProxyUserName, ProxyPassword, HTTPREQUEST_SETCREDENTIALS_FOR_PROXY);
WinHttp.Send(Null);
Result := WinHttp.ResponseText
Re: using a proxy
Posted: Fri Sep 17, 2010 2:00 am
by isopor
It sounds good. This is what I need. I added this to the beginning of the script and updated the proxyserver, proxyusername and proxypassword accordingly.
When I test locally it (test transcoding/default device) it works. But when I try it from the TV I get an error. It doesn't even start the download. Nothing appears on the temp folder. I got a quick DOS window that closes right away.
Looking the log I found this suspicious:
"22:25:03.951 [Transcoding] Sender: TWmsTranscodingThread.Execute
Access violation at address 00AA9771 in module 'wms.exe'. Read of address 49005868
I also tried the script with other working podcast (not iplayer). I used blanks for proxy server and username and then it failed to work either.
Can you see what is wrong? Anything I could try?
Re: using a proxy
Posted: Fri Sep 17, 2010 4:41 am
isopor wrote:It sounds good. This is what I need. I added this to the beginning of the script and updated the proxyserver, proxyusername and proxypassword accordingly.
Yes, unfortunately when you play on your device it will not work (problem with CreateOleObject). This will be possible in the next version.
Re: using a proxy
Posted: Fri Sep 17, 2010 11:12 am
by isopor
Thanks. I am looking forward to it then.
Re: using a proxy
Posted: Sun Apr 17, 2011 6:45 am
by DooBop
HI,
is there some progress to force some internet streams via specific proxy?
Tnahx
Re: using a proxy
Posted: Sun Apr 17, 2011 7:01 am
Re: using a proxy
Posted: Sun Apr 17, 2011 7:12 am
by DooBop
in which trans profile ? I did it in internet television profile - no success .Shoud I use const two times? I do not need username and password. Can I delete that rows?
Maybe (if You have time) can You try this:
here is stream and proxy
mms://straumv.nrk.no/nrk_tv_direkte_nrk1_h
148.122.38.200:8080
Re: using a proxy
Posted: Sun Apr 17, 2011 9:27 am
148.122.38.200:8080
Settings - Transcoder - Profiles - 'Internet-television" - Edit
csVideoLanParams =
'--no-crashdump -Idummy --language=en --mmsh-proxy=148.122.38.200:8080 --sout=#transcode' +
Re: using a proxy
Posted: Mon Apr 18, 2011 6:37 am
by DooBop
Great.
Thanx E
