Re: Mdapi filter
Posted: Mon Sep 13, 2010 12:08 pm
skandy wrote:there is any way to use mdapi filter with wild media server for DVB streaming?
There was information, that can be used DVBLink for this.
Re: Mdapi filter
Posted: Mon Sep 13, 2010 1:46 pm
skandy wrote:Today I am using mediaportal as a tv and media player solution. With mediaportal tv server I am using an mdapi filter. There is a plugin in mediaportal to stream tv trough http.
With this settings, i am able to configure in wild media server, at internet TV settings, a url. With this i am able to stream the TV and SAT channels to a DNLA Television in my room, from the living computer.
In Wild media server you have an integrated tunner, and you can stream directly the DVB channels, but I don't figure how to integrate the mdapifilter with Wild media server. (with this solution i will be able to stream the channels withouth using mediaportal at all).
How you can integrate DVBLink with Wild media server? I don't understand exactly what are you talking about.
Thank you!!!
skandy wrote:The question is if Wild Media Server can support directly the MD api filter, to use other plugins with it.
WMS uses DVPiper (http://www.cs.usyd.edu.au/~efax/DVPiper.html) to support DVB. MD api filter not be used.
