Page 1 of 2
				Doesnt Show After Couple Minutes
				Posted: Thu Jan 28, 2010 7:28 pm
				by tyler78
				I've solved my subtitle problem. Now i have another problem.
Basicly;
I'm playing avi and mkv videos without transcoding and showing subtitles with transcoding. It looks perfect but it stops playing after 1 minute. Why is that? How can i solve this?
				Re: Doesnt Show After Couple Minutes
				Posted: Thu Jan 28, 2010 7:54 pm
				tyler78 wrote:I've solved my subtitle problem. Now i have another problem.
Basicly;
Perhaps the speed of transcoding is not enough to view. On the right-button mouse in the list of films you can perform a test transcoding, transcoding speed (parameter fps) must be greater than the frame rate the movie.
				Posted: Thu Jan 28, 2010 8:03 pm
				by tyler78
				But i am only transcoding subtitle. How can it transcode so slow to stop the video?
I did the test transcoding. Didnt understand which must be what. Can you tell me whats wrong?
				Posted: Thu Jan 28, 2010 8:26 pm
				tyler78 wrote:But i am only transcoding subtitle. How can it transcode so slow to stop the video?
With the speed of transcoding, no problem. Try to disable "Maximum advance transcoding" (Transcoder - Execution of transcoding) - set 0. Transcoder - "Codecs, frame" - File format - "MPEGTS (MPEG Transport stream)".
				Posted: Fri Jan 29, 2010 3:59 am
				by tyler78
				@Eugene
Yes, that solved my problem with avi files. But now, when i play mkv files, it stops and continues. Every few minutes, stops and continues.
One more question. That "Maximum advance transcoding" setting, what does it do? When i make it 30 or 0, what is the difference?
				Posted: Fri Jan 29, 2010 7:44 am
				tyler78 wrote:@Eugene
If 0, then the transcoding occurs at maximum speed (greater use of computer resources). If greater than 0, then there is an alignment speed transcoding to work with this advance.
				Posted: Fri Jan 29, 2010 5:05 pm
				by tyler78
				How can i solve that stops-continues problem with mkv? Do you have a solution? My pc is strong and i have lots of space. That's not the problem i guess. There is something with the settings.
				Posted: Fri Jan 29, 2010 5:12 pm
				tyler78 wrote:How can i solve that stops-continues problem with mkv? Do you have a solution? My pc is strong and i have lots of space. That's not the problem i guess. There is something with the settings.
What is the speed of transcoding?
				Posted: Sat Jan 30, 2010 5:16 pm
				by tyler78
				Where can i see that?
				Posted: Sat Jan 30, 2010 5:21 pm
				tyler78 wrote:Where can i see that?
Test transcoding (parameter fps)
