Scraping adjustment
Posted: Mon Sep 06, 2010 9:34 am
by libero
I've noted that when scraping the IMDB (or the others) site for the movie informations the standard keywords include the file extension (e.g. avi). In this way IMDB ( i don't know the other sites) get confused and often does not return the correct answer. Could you please remove the file extension from the standard keywords ?
Libero
Re: Scraping adjustment
Posted: Mon Sep 06, 2010 10:26 am
libero wrote: I've noted that when scraping the IMDB (or the others) site for the movie informations the standard keywords include the file extension (e.g. avi). In this way IMDB ( i don't know the other sites) get confused and often does not return the correct answer. Could you please remove the file extension from the standard keywords ?
In the next version
Posted: Mon Sep 06, 2010 11:01 am
by libero
Perfect
