CyberLink PowerDVD version 10 Ultra 3D
Posted: Mon Aug 16, 2010 6:08 pm
by djo_34
Has anyone tried PowerDVD's UPnP client feature with WMS?
I downloaded it and can navigate the WMS folder structure, but no files are displayed in the folder so I can't stream anything.
I was curious if anyone has tried this and had any luck.
Are there any Windows UPnP Clients that work with WMS???
Re: CyberLink PowerDVD version 10 Ultra 3D
Posted: Mon Aug 16, 2010 7:37 pm
djo_34 wrote:Has anyone tried PowerDVD's UPnP client feature with WMS?
Device type: Philips TV 2008 (DLNA, 16:9, 1280x720)
Client features are very limited at first glance.
djo_34 wrote: Are there any Windows UPnP Clients that work with WMS???
WMP, Nero, XBMC. Best of all I think VLC in a web-mode.
Posted: Mon Aug 16, 2010 10:11 pm
by djo_34
Any Windows UPnP clients that support MKV?
WMP and Nero don't. VLC uses PowerDVD plugin. If PowerDVD doesn't work, my guess is that VLC doesn't either.
But thanks for the response.
Posted: Tue Aug 17, 2010 7:31 am
djo_34 wrote:Any Windows UPnP clients that support MKV?
WMP and Nero don't.
I installed Haali Media Splitter (http://haali.su/mkv/). Now WMP support mkv (Windows 7), PowerDVD doesn't work.
XBMC also have no problems.
djo_34 wrote: VLC uses PowerDVD plugin. If PowerDVD doesn't work, my guess is that VLC doesn't either.
VLC contains everything you need for playback most common formats, problems c mkv not.
