QuickTime install ?
Posted: Thu Aug 05, 2010 5:01 pm
by Torsten.E
Must i install QuickTime to show "mov"-Files ?
Re: QuickTime install ?
Posted: Thu Aug 05, 2010 5:12 pm
Torsten.E wrote:Must i install QuickTime to show "mov"-Files ?
No, it is not required.
Posted: Fri Aug 06, 2010 8:11 am
by Torsten.E
Ok, and what setting I need to make that mov files are played. At present there is not yet
Posted: Fri Aug 06, 2010 12:11 pm
Torsten.E wrote:Ok, and what setting I need to make that mov files are played. At present there is not yet
No to the device or on the main form of the program?
Posted: Fri Aug 06, 2010 12:29 pm
by Torsten.E
Posted: Fri Aug 06, 2010 12:51 pm
What type of device used?
Posted: Fri Aug 06, 2010 1:14 pm
by Torsten.E
PLAYON!HD mini (A.C.Ryan)
(new Chipset 72300 DDC+)
Posted: Fri Aug 06, 2010 1:20 pm
Torsten.E wrote:PLAYON!HD mini (A.C.Ryan)
Try to use the configuration "WD TV Live HD Media Player (DLNA, 16:9, 720x406)"
On the main form of the program file exists ?
Posted: Sun Aug 08, 2010 10:42 am
by Torsten.E
Hey Eugene, it didn't stream the mov file
Posted: Sun Aug 08, 2010 2:45 pm
Torsten.E wrote:Hey Eugene, it didn't stream the mov file
Works via USB?
