Problem with Sony Bravia and .avi files ...
Posted: Sat Jun 26, 2010 10:46 am
by Angel2k6
As the title, i have problem with .avi files ..
i succeed to watch mpg video (also mp3 and jpg) without problem...but not the avi ones..
what i have to do?
My tv model is: 40nx700 ..
Tnx in advance
Re: Problem with Sony Bravia and .avi files ...
Posted: Sat Jun 26, 2010 11:39 am
Angel2k6 wrote:As the title, i have problem with .avi files ..
what i have to do?
Settings - Device - Type - "Sony TV (DLNA, 16:9, 1280x720)"
or
Settings - Server - to choose a device - Edit - Settings Type - "Sony TV (DLNA, 16:9, 1280x720)"
Posted: Sat Jun 26, 2010 12:49 pm
by Angel2k6
okok thank you so much ..
now i succeed to watch also avi files...
but... with freezes ..what's the problem? could I optimize avi's streaming?
tnx
Posted: Sat Jun 26, 2010 1:00 pm
Angel2k6 wrote:okok thank you so much ..
On right click of the mouse you can perform a test transcoding, if transcoding speed (fps) is less frame rate, then the playback will be slow. You can use the pre-transcoding (Settings - Processing), but it is better to buy a network media player, which supports lots of formats.
Posted: Sat Jun 26, 2010 2:23 pm
by Angel2k6
this is my test..
fps seems higher than file's frame rate (25)..
Posted: Sat Jun 26, 2010 2:37 pm
Angel2k6 wrote:this is my test..
WiFi or wired connection?
You can try enable buffer of transcoding (Settings-Transcoder-Other(Buffer)), may problems associated with disk operations.
Posted: Sat Jun 26, 2010 2:56 pm
by Angel2k6
wifi connection...
nothing .. i've enabled Settings-Transcoder-Other(Buffer) with ...but it's the same..
Posted: Sat Jun 26, 2010 3:01 pm
Angel2k6 wrote:wifi connection...
Most likely a problem with this.
Posted: Sat Jun 26, 2010 3:42 pm
by Angel2k6
but transmission bitrate is 2,5 MB/sec...is it too slow?
i've just noticed that problem is with ALL video files..not just avi..
Posted: Sat Jun 26, 2010 4:00 pm
Angel2k6 wrote:but transmission bitrate is 2,5 MB/sec...is it too slow?
If possible, connect the wire and check.
