Page 1 of 2
No sound when playing .mkv files!!
Posted: Fri Jun 25, 2010 7:34 pm
by YoavBZ
I'm using a LG LE5500 TV who should support mkv files without any problems..
All the video files (except the mkv once) work excellent! But when I'm trying to play any mkv files I get no sound..
I've being trying to change some setting in the software in order to fix it but it didn't solve the problem.
What should I do?
P.S.
I think the audio codec is DTS.
Re: No sound when playing .mkv files!!
Posted: Fri Jun 25, 2010 8:35 pm
by YoavBZ
Thank you, Klausi69, for the PM.
So, yes, It could be a general problem in the LG TVs, but I'm trying to fix it.
can I transcode it or something? (It's kind of new to me so I could use some help :D )
Posted: Sat Jun 26, 2010 12:23 pm
by YoavBZ
Wow it works!! Thanks! But it's very slow.. Every few seconds it stops and loads the movie. What can I do?
Posted: Sat Jun 26, 2010 1:53 pm
by YoavBZ
I'm using Windows XP sp3, with Intel e6550 processor (core2due, 2.33 GHz, 4M cache), 2GB ram, Ethernet connection (100Mbps)...
Posted: Wed Jun 30, 2010 4:51 pm
by YoavBZ
Someone?
Posted: Thu Jul 01, 2010 5:58 am
YoavBZ wrote:I'm using a LG LE5500 TV who should support mkv files without any problems..
What should I do?
By right-click the mouse in the list of films, to choose transcoding profile "Movies-TsMuxer"
Posted: Sun Jul 18, 2010 10:09 am
by YoavBZ
Eugene wrote: By right-click the mouse in the list of films, to choose transcoding profile "Movies-TsMuxer"
I did, and it works! but very very slow.. what can I do to make it faster?
YoavBZ wrote: I'm using Windows XP sp3, with Intel e6550 processor (core2due, 2.33 GHz, 4M cache), 2GB ram, Ethernet connection (100Mbps)...
Posted: Sun Jul 18, 2010 4:15 pm
Maybe off subtitle selection
Posted: Fri Jul 23, 2010 8:44 pm
by YoavBZ
Eugene wrote:Maybe off subtitle selection
I'm using this program because of the subtitle support.
Is there any other solution that'll make the video streaming faster? Maybe something related to the script code? Remember that the only problem is the audio codec. Perhaps I can only transcode the audio, so it will ignore the video transcoding?
Posted: Sat Jul 24, 2010 1:22 pm
If your device does not support subtitles, you need to recode the video. You can use the pre-transcoding (Settings-Processing).
