Page 1 of 3
Problem playing a certain TV stream
Posted: Thu Jun 17, 2010 8:03 am
by grolschie
Hello.
Here is the URL:
mms://a120.l7085830119.c70858.g.lm.akamaistream.net/D/120/70858/v0001/reflector:30119
Clicking "Read properties from a file" shows that its 640x480 WMV.
However, a test transcode show the following:
"C:\Program Files\Wild Media Server\wmsmpeg.exe" "C:\Program Files\VideoLAN\VLC\
vlc.exe" -Idummy --language=en --sout-ffmpeg-strict-rc --sout=#transcode{vcodec=
mp2v,vb=8000,fps=24,width=464,height=576,scale=1,vfilter=croppadd{paddleft=128,p
addright=128,paddtop=0,paddbottom=0},aspect=16:9,acodec=mpga,ab=192,channels=2,s
amplerate=48000}:duplicate{dst=std{access=file,mux=ps,dst="D:\WMS_TEMP\WmsTemp\T
est_a6fc072af1bed16aef67e7dce2c55ba0.mpg"}} "mms://a120.l7085830119.c70858.g.lm.
akamaistream.net/D/120/70858/v0001/reflector:30119"
[00bf0e64] dummy interface: VLC media player - version 1.0.5 Goldeneye - (c) 199
6-2010 the VideoLAN team
[00bf0e64] dummy interface: using the dummy interface module...
[00cac314] mux_ps mux: Open
[00cb06fc] access_mms access error: failed to open a connection (tcp)
[00cb06fc] access_mms access error: cannot connect to server
[00cb06fc] access_mms access error: cannot read data 2
Is there anything I can do please? Thanks in advance.
Re: Problem playing a certain TV stream
Posted: Thu Jun 17, 2010 8:15 am
grolschie wrote:
Here is the URL:
The same message, but transcode the file was successfully created.
Check the directory for temporary files of transcoding.
Posted: Thu Jun 17, 2010 9:35 am
by grolschie
Thank you for that. Very interesting. It did actually manage to make a transcode file. Hmm.. but it doesn't seem to stream live to the BDP-S370 even though it's set to transcode to MPG like the other TV streams I have got.
Interestingly, the transoded file seems to have the wrong aspect ratio when played in VLC on my PC. It looks like the original should be 4:3, but it's like a 16:9 frame has been squeeze into a 4:3 frame. Everything looks too thin. I have a couple of streams that play with a similar effect. Is there a way to force a correct aspect ratio please?
Some streams give unsupported or corrupt file error when streaming to the player, yet when attempting to play again, they work. I am not sure why that is.
Posted: Thu Jun 17, 2010 10:01 am
grolschie wrote:Thank you for that. Very interesting. It did actually manage to make a transcode file. Hmm.. but it doesn't seem to stream live to the BDP-S370 even though it's set to transcode to MPG like the other TV streams I have got.
Settings-Transcoder-Profiles-"Internet-television"-Edit-Transcoding parameters
Try replace on
function GetAudioCodec(const aFileFormat: string): string;
if SameText(aFileFormat, 'ASF (Windows Media Format)') then
Result := 'wma2'
else
Result := 'mpga'
function GetFileFormat(const aFileFormat: string): string;
Result := 'asf'
else if SameText(aFileFormat, 'MPEGTS (MPEG Transport Stream)') then
Result := 'ts'
else if Pos('SONY', UpperCase(cfgDeviceType)) > 0 then
Result := 'ps'
else
Result := 'mpeg1'
function GetVideoCodec(const aFileFormat: string): string;
Result := 'wmv2'
else
Result := 'mp2v'
csVideoLanParams =
'"<VLC>" -Idummy --language=en --sout-ffmpeg-strict-rc --sout=#transcode' +
'{vcodec=%s,vb=%d,fps=%s,scale=1,acodec=%s,ab=%d,channels=2,' +
' "<INPUT FILE>"'; // vlc:quit
bVLC098: Boolean;
sPadFormat, sFrameRate, sPadParams, sDeinterlace: string;
bVLC098 := WmsVlcVersion >= '0.9.8';
if WmsGetVideoSettings(vstDeinterlace) = 'on' then
sDeinterlace := ',deinterlace'
else
sDeinterlace := '';
if mpInternetItem then
sFrameRate := '24'
else if cfgTranscodingFrameRate <> '' then
sFrameRate := cfgTranscodingFrameRate
else if mpFrameRate > 0 then
sFrameRate := FormatFloat('0.000', mpFrameRate)
else
sFrameRate := '25';
if SameFloat(sFrameRate, '23.976') then
sFrameRate := '24'
else if SameFloat(sFrameRate, '29.970') then
sFrameRate := '30'
else if SameFloat(sFrameRate, '59.940') then
sFrameRate := '60';
TranscodingParams := Format(csVideoLanParams,
[GetVideoCodec(cfgTranscodingFileFormat),
12000, sFrameRate,
GetAudioCodec(cfgTranscodingFileFormat),
Min(cfgTranscodingAudioBitrate div 1000, 192),
sDeinterlace, GetFileFormat(cfgTranscodingFileFormat)])
Posted: Thu Jun 17, 2010 10:26 am
by grolschie
Thanks for that. The URL I posted above now just sits loading and loading....
But, I have a big problem now. After changing a transcoding setting, I saw a Windows Disk Missing (or something) error, and now all my streams are gone. All the TV and Radio streams are gone. When I view the any of the "Movie", "Music" or "Photo" folders on the player all I now see are only 3 options: "Media Database", "Media Device" and "Media Server". Everything is gone. All my disk drives are visable in Windows Explorer, so I don't know what has happened.
EDIT: The table field in WMS just says: <No data to display>
Posted: Thu Jun 17, 2010 10:37 am
by grolschie
It appears that my entire WMS database disappeared. All my TV and radio presets, and local media, gone. I had set it to not show emtpy folders. After a re-scan the local media is back, but no Internet TV streams. I did an export of my radio presets (and have re-imported them), but not my tv presents.
Maybe I clicked something wrong? I quite often click accidentally with my trackpad.
Posted: Thu Jun 17, 2010 11:43 am
grolschie wrote:Thanks for that. The URL I posted above now just sits loading and loading....
grolschie wrote:It appears that my entire WMS database disappeared. All my TV and radio presets, and local media, gone. I had set it to not show emtpy folders. After a re-scan the local media is back, but no Internet TV streams. I did an export of my radio presets (and have re-imported them), but not my tv presents.
Backups: Help - Backup.
If define the sequence of clicks leading to the error, then I'll try to fix this problem.
Posted: Thu Jun 17, 2010 11:46 am
by grolschie
Oh dear. I didn't see that option. That is a very nice feature. Thank you very much. I have started entering my presets again, and will definitely use the backup feature. Thanks very much.
Posted: Thu Jun 17, 2010 12:21 pm
by grolschie
Eugene wrote: Settings-Transcoder-Profiles-"Internet-television"-Edit-Transcoding parameters
Try replace on....
Thanks for this. It works. When applied to 4:3 channels it does stretch nicely to 16:9.
I have one channel where is seems that it's being cropped at the top and bottom to fit 16:9:
http://live.onestreaming.com/elladatv
Is there a way around this also please? Thanks in advance.
Posted: Thu Jun 17, 2010 12:38 pm
by grolschie
Correction: Please ignore the part about the missing disk error. That was an message relating to another application that I was running at the same time. I am sorry about that.
